Results 21 to 30 of 32
Thread: Assembling SSR's (with daisey chain option)
    5,341
    Default Re: Assembling SSR's (with daisey chain option)
    You have to be careful with all boards that have power-line voltages on them. However, I was specifically referring to the perf-board approach.
    carol stream, illinois
    95
    ...Just to go back a bit
    Mostly all "household extension cords" are 16 AWG, this is NOT RECOMMENDED for a 15 AMP load. Typical household wiring (in the wall) is 14 AWG for a 15 AMP circuit / 12 AWG for a 20 AMP.
    this is to maintain "safety specifications" for the most part, every guage wire can (theoretically) handle more than the "rating" but is not advisable in any means.
    Just "food for thought", when I was 13 I MELTED the main breaker in my panel, I didn't wedge it open, it just melted. ANYTHING can fail, including safety devices.
    Just be careful when "loading" circuits
    Have you heard, well, it was my understanding that everyone has heard. BA BA BA BA BA OOM MOW MOW, BA BA OOM BOW BA BOW, don't you know about the bird.
    "At least I'm not considered crazy here, but yet an amateur."
    Nov 2008
    16
    I may use the same philosophy I use at work. When I need to lift a 500 pound load, I design the lifting fixture to be rated at 1000 pounds.
    Nov 2008
    kentucky
    95
    i was wandering if it is still possible to get the ssr pcb
    Long Island, NY
    7,671
    Quote Originally Posted by kfindley View Post
    Send a PM to Wjohn, he keeps them available.
    Nov 2008
    Orlando, Florida
    34
    I got a question about using this method and my ssr boards. I built everything just like Wayne has and put my boards and outlets into the box and made sure nothing was touching. Now when I plug in the power should the led light up? Or do I need to connect everything, grinch and lights to outlets, for the led to work? Because I'm not getting the led lite up when I just plug the power cord into an outlet.
    Rick
    Nov 2008
    Bel Air, MD
    94
    Quote Originally Posted by RStetson View Post
    Rick
    I believe the power to the LED on the SSR is coming from the DC power on the controller, Not the AC. At least mine appears to work that way. When I plug in the cat5, presto the LED lights up. I dont believe I get anything plugging into the wall.
    David
    Charlotte, NC
    824
    Rick - David is correct - The LED does NOT get it's power from the SSR's, but from the controller board it's connected to.
    Buffalo, NY
    857
    An important thing to note is that you can have 110 V on the SSR and no LED lit up. So don't use the LED as an indication that it is safe to touch or not.
    1 channel, 0 dimmable. Powered by a man flicking a lightswitch to the beat.
    Kansas, Wichita
    48
    New Questions but they fit well in this discussion
    I thank my SSR kits that are in the mail are top plug RJ45 jacks I like the side plug idea. I Donít know which plug to buy from Mousur without a part Number they have hundreds of RJ45 plugs.
    OR I have some network jacks and plates I could mount on the side of the box, I was thinking I could make little patch cords to go from the plated jack to the pcb. and punch down the cat 5 cable to my connector, now do I put ends on the cat5 and plug them in to the top plug, will I have room in the box or can I solder the cable strait to the PCB?
    This is my out of box thinking there is a significant price difference between the blue boxes with the push through wire clamp and the blue boxes with KO holes. I was thinking of using spray foam insulation to water seal the box and hold the board like a stand off but I am concerned about whether there is enough heat or spark to catch the foam on fire.
    how water tight does the box need to be the little gap between the plug and the plate will let water in.
    Thanks Phillip
    2010: One orbit yard sprinkler controller 5 zones 2 schedules that turn on at 4 different times each. 20 form C contact relay and creative use of the chasing controller that come with the lights.
    2011: 2 renard ss24, Two renard 64xc, and Fm transmitter. 13000 lights
    2012: Planning 4 renard ss24, 2 renard ss8, 1 renard 64xc, 1 renard 64xc for RGB LED and Fm transmitter. ???? Lights
