Ok a few assuptions I'm making for this to be a benifit:
Some users already have the cheap usb to serial convertors that can handle the 115K speed (most all can do this its the faster ones that cost)
For those that dont these cheap units cost very little $9 - $20
for some of our members the current offerings of DMX dongles at $60 - $150 is a healty expense.
That the majority of the members are not running lights shows of over 192 channels.
Ok, if this is true then here are some facts :
It is easy to write pic code to send dmx data.
Pic's are cheap
It is easy to write code to recieve 115K serial data
streaming serial data out to the usb to serial convertors is easy for vixen
With this in mind what about this for a cheap homebuilt DMX solution of our own.
Program a pic to recieve a 115k stream of data from vixen just like you do for the entec pro dongles and then to send out the dmx stream from the pic.
So you would have a little sub dongle that plugs into you serial convertor and then you plug you output cable to it and you have DMX. The pic would keep up the dmx stream not the computer just like in the Entec Pro.
The first thought is 115k is not fast enough from the port to feed a dmx stream. This is true for a full 512 channel stream but what about a trunucated or "Short frame" of 192 channels. hopefully you agreed that most of use do not even do 192 ch shows. The data stream would be legitimate dmx and should work other dmx equipment.
The end would be a product for those not wanting to speed the money of the more expensive solutions and not needing 512 channels on one usb port.
I believe this would be a very inexpensive way to do this.
Let me say right up front I am not purposing this for myself I will gain nothing from it I am simply trying to come up with a dirt cheap alternative for our members to use that would like to move to dmx. I am in hope that in time the equipment the DIY'ers are using can move to one protocol which multiple different devices can use instead of continuing to create devices that all use different protocols which require each different type of device to be hooked to a different port and another feed from our computers. I know the value my opinon carrys here but I would hope good ideas are universial. I have learned from the other indurstries I work and play in that without a common standard to work from progress slows. If the computer industry had not given up all the different companies independant standards and settled on solid standards across the industry you would not be reading this right now. (so you can blame them).![]()
