And the error log:
Warning 1 The field 'Vixen.Sys.Output.IntervalUpdateSignaler._lastUpda teTime' is assigned but its value is never used C:\My Projects\vixen3\Vixen.System\Sys\Output\IntervalUp dateSignaler.cs 9 16 Vixen
Warning 2 The field 'Vixen.Module.Effect.EffectModuleInstanceBase.prer endCnt' is assigned but its value is never used C:\My Projects\vixen3\Vixen.System\Module\Effect\EffectM oduleInstanceBase.cs 24 23 Vixen
Warning 3 Unreachable expression code detected C:\My Projects\vixen3\Vixen.System\Sys\Managers\Hardware UpdateThread.cs 161 33 Vixen
Warning 4 Unreachable code detected C:\My Projects\vixen3\Vixen.System\Sys\Output\OutputCont roller.cs 167 8 Vixen
Warning 5 The using directive for 'System.Linq' appeared previously in this namespace C:\My Projects\vixen3\Common\ScriptSequence\Script\Scrip tProjectGenerator.cs 7 7 ScriptSequence
Warning 6 Missing XML comment for publicly visible type or member 'Dataweb.NShape.WinFormsUI.Display.ScrollBy(int, int)' C:\My Projects\vixen3\Common\NShape\WinFormsUI\Display.c s 4680 15 NShapeWinFormsUI
Warning 7 Missing XML comment for publicly visible type or member 'Dataweb.NShape.WinFormsUI.Display.ScrollTo(int, int)' C:\My Projects\vixen3\Common\NShape\WinFormsUI\Display.c s 4686 15 NShapeWinFormsUI
Warning 8 The field 'VixenModules.Preview.VixenPreview.VixenPreviewMod uleInstance.UseOldPreview' is assigned but its value is never used C:\My Projects\vixen3\Modules\Preview\VixenPreview\Vixen PreviewModuleInstance.cs 17 16 VixenPreview
Warning 9 The field 'VixenModules.Preview.VixenPreview.VixenPreviewMod uleInstance.UseOldPreview' is assigned but its value is never used C:\My Projects\vixen3\Modules\Preview\VixenPreview\Vixen PreviewModuleInstance.cs 17 16 VixenPreview
Warning 10 Unreachable code detected C:\My Projects\vixen3\Modules\Preview\VixenPreview\Vixen PreviewSetupElementsDocument.cs 62 4 VixenPreview
Warning 11 Unreachable code detected C:\My Projects\vixen3\Modules\Preview\VixenPreview\Vixen PreviewSetupElementsDocument.cs 62 4 VixenPreview
Warning 12 The event 'VixenModules.Preview.VixenPreview.VixenPreviewCon trol.OnElementsChanged' is never used C:\My Projects\vixen3\Modules\Preview\VixenPreview\Vixen PreviewControl.cs 84 50 VixenPreview
Warning 13 The event 'VixenModules.Preview.VixenPreview.VixenPreviewCon trol.OnElementsChanged' is never used C:\My Projects\vixen3\Modules\Preview\VixenPreview\Vixen PreviewControl.cs 84 50 VixenPreview
Warning 14 The field 'VixenModules.Preview.VixenPreview.VixenPreviewMod uleInstance.isGdiVersion' is assigned but its value is never used C:\My Projects\vixen3\Modules\Preview\VixenPreview\Vixen PreviewModuleInstance.cs 201 8 VixenPreview
Warning 15 The field 'VixenModules.Preview.VixenPreview.VixenPreviewMod uleInstance.isGdiVersion' is assigned but its value is never used C:\My Projects\vixen3\Modules\Preview\VixenPreview\Vixen PreviewModuleInstance.cs 201 8 VixenPreview
Warning 16 The field 'VixenModules.App.Shows.PauseAction.process' is assigned but its value is never used C:\My Projects\vixen3\Modules\App\Shows\Actions\PauseAct ion.cs 12 19 Shows
Warning 17 The variable 'lastUpdate' is declared but never used C:\My Projects\vixen3\Modules\Output\E1.31\E131OutputPlu gin.cs 536 22 E131
Warning 18 Field 'VixenModules.Output.K8055_Controller.K8055Module. _Offset' is never assigned to, and will always have its default value 0 C:\My Projects\vixen3\Modules\Output\K8055 Controller\K8055Module.cs 18 15 K8055 Controller
