Results 1 to 9 of 9
Thread: Happy Easter!
    2,147
    Default Happy Easter!
    Here is a short little Easter sequence using xLights, modified Renard controller, and a WS2811 garage door grid:
    http://www.youtube.com/watch?v=1BzcQ_St3UI
    This was a "purpose driven" demo/test for some of the recently added xLights features.
    don
    Click for display details >>
    6,148
    Default Re: Happy Easter!
    This looks great Don .
    Are you using the square style pixels on this grid ?
    Sep 2013
    Ontario, Canada
    724
    Nice Job!!
    Winter Haven Florida
    3,039
    very nice
    James WinterHaven Fl
    2,147
    Thank you all for the complements.
    No, actually these are just regular 5V WS2811 60/m LED strip cut apart and then spaced out to 3.5 inch spacing using strands of cat3 (same wire as cat5, just less effort to unwind them). It was somewhat tedious, but much less expensive to cover a larger area this way. (later I did find a place that actually makes LED strip with 10 cm spacing, but the DIY approach cost less money). Then I put the pixels back in silicon tubes and when I mounted them I pointed them backwards so they act like miniature spot lights shining onto the garage door surface.
    Gdoor-pixels-P1330253.jpg Gdoor-strips-P1330258.jpg Gdoor-mounted-P1330280.jpg
    This was a "technology refresh" of an earlier version which is described here:
    http://downloads.eshepherdsoflight.c...BPixelGrid.pdf
    I prefer this style of gdoor grid because it's practically invisible in the daytime from several feet away (and totally invisible hardware at night), and the garage door is still operational (even when the lights are running). This time around, I used WS2811 instead of chipiplexed LEDs. The cut up pieces of LED strip make great little PCBettes, and were a lot easier to work with than bare LEDs. I also mounted the controller and power supply on the back side of the door this time, which made the front appearance a lot cleaner than how I did it the first time around.
    don
    10,283
    I've got a whole pile of them little varmints from my star build - nice job!
    [/SIZE]
    [/COLOR][/I]
    6,148
    don
    Wow , that is a ton of work/time invested to create that grid . Very creative Don . I guess I should have expected this coming from you though .
    I could not figure out how the light was so square in shape without spillage . awesome idea.
    Albuquerque, NM, US of A.
    633
    Looks Great Don, love the message itself!
    2,147
    I have the stand-offs set so that the pixels will overlap slightly when they are on full intensity, but if they are dimmer then there is a slight gap. This way I can control whether they run together at the edges or not, to give a slightly different look to it (I can also adjust the standoffs manually if needed). When the colors blend at the edges, it makes the graphics look less blocky even though this is a low-res grid.
    They also make handy testers, or even "front panel" devices - since they only take 1 I/O pin to run they don't take much extra hardware, just a spare I/O pin.
    don
