Page 3 of 8 FirstFirst 12345 ... LastLast
Results 21 to 30 of 77
Thread: Masking & Video Production for a Projector the Easy Way
    Jan 2013
    Bristol, CT
    1,490
    Default Re: Masking & Video Production for a Projector the Easy Way
    Yeah, You guys are right about that. I will stick to the left section of the house. Will the projection be visable while the rest of the show is going? Or do I have to have that part of the house be in the dark while projecting? Ok so it looks like I too will be ordering the GT760. Quick question on that. If I have the projector turn on with a timer, will it be able to play or are there some button that need to be pushed to have it ready for playback? BTW I just ordered the PowerDirector 12 with the discount, Thanks Poolprousa!
    Jan 2014
    Elkmont Alabama
    85
    Quote Originally Posted by Robo View Post
    You're welcome, you will have lots of fun with PD and your new PJ. Yes, ambient light will have an effect on your projected image, you will just have to test it to see how much. I plan on sequencing the lights that are adjacent to my "screens" to not be too active during key portions of video that I want to put emphasis on, as a precaution to too much light saturation. That being said, I have a streetlight close to my front yard (that I will get a switch on before Dec); It has very little effect on my projections
    If the PJ is on, it will receive and play automatically whenever it receives a signal. However, powerdown should be done manually, which is a 2-stage process for the PJ; 1st step allows it to cool the lamp down before 2nd step which finalizes shutdown
    [edit] timer won't work, it has a power on switch you must press
    [url=http://nutcracker123.com/forum/index.php?topic=20.0]Forum Link to My Show Setup[/url]
    Xenia, Ohio
    1,354
    Robo,
    Amazon has the Optoma unit for $590.98 if you have a Prime membership.
    [SIGPIC][/SIGPIC]
    [/COLOR]
    Jan 2013
    Bristol, CT
    1,490
    Neweggs still $2 cheaper. I'll be ordering it today! Woo hoo!
    Eagan, Mn.
    4,074
    Poolprousa rather than the 50 ft cable why not have a wireless router and use the ethernet input on the projector?
    Sent from my SCH-I545 using Tapatalk
    Jan 2014
    Elkmont Alabama
    85
    I am real weak in networking, especially wireless. I'm doing good to having my home/WHS2011 server set up with Plex I'm sure wireless is possible, I just am intimidated by it...plus the FPP has HDMI out, I'm bringing my projector inside after every show, so running the cable is no big deal for me. I would still be very interested if someone knows of a wireless solution, and would post it, maybe start a new topic
    Eagan, Mn.
    4,074
    Ok, so why not use a short cable and have the pi right there too?
    Eagan, Mn.
    4,074
    I'm not putting you on the spot, and I haven't done this either. But I have read about more than one person using wireless to their projector, and another person using the pi player to run the projector (mp4s on the flash card, not FPP). So I am just fishing to put it all together. With a Rasclock you can have the FPP run stand alone in the yard with the projector and the ethernet E131 out of the pi to the rest of the show (add a bridge if you need some renard or dmx). I guess I'm a little off topic but when you mentioned FPP I had to ask.
    Jan 2013
    Bristol, CT
    1,490
    they do sell wireless hdmi , tho it's on the expensive side.
    6,748
    This is exactly the method I plan to use , rather than a media player or running cables .
