Results 1 to 9 of 9
Thread: Help - still can not get the DIO 96 card recognized
    Iowa - Gods country
    850
    Default Help - still can not get the DIO 96 card recognized
    Ok , here's the whole story .
    Brand new ( sealed NIB ) PCI DIO 96 cards ( tried only one in the PCI slot first then tried the other , so I know its not a hardware problem .
    Now , after installing both the software AND the hardware , when I go to start VIXEN , this is what comes up :
    Ni DIO 96. dll:
    Could not load type ' Vixen,version=2.0.5.1 , culture= neutral, PublicKey token= null'
    Now , I get this TWICE when starting up VIXEN and also get it when I try to SETUP PLUGINs .
    The only type of DIO listed in the PLUGINs ( after I start the VIXEN program ) that is listed , is :
    MCC DIO
    BTW - this PC is NOT online , nor , is it hooked to be .
    So , could anyone tell me what the heck am I doing wrong here ?
    ( now , this PC that I am trying to use these on , is running a 2.4 CPU with 1 gig of DDR , 450 watt PS , and has 3 PCI slots , of which , one is taken by a sound card , twin 100 gigger HD's - all tested and stressed with Sisoft Sandra )
    Ft. Walton Beach, FL
    1,501
    Default Re: Help - still can not get the DIO 96 card recognized
    Bob,
    You must have missed the posts dealing with the PCI-DIO-96 and that the plug-in only currently works with Vixen Ver 1.1.11. If you want to use the PCI-DIO-96 cards with Vixen then you need to go back to version 1.1.11.
    RavingLunatic
    Iowa - Gods country
    850
    Thanks ... for some reason , I thought I read that someone was running ( or ran ) two in one of the newer BETA's
    jeffathompson Guest
    Quote Originally Posted by TERBObob View Post
    Nope, nothing for anything higher than 1.1 yet. Have you had these running on 1.1? I had trouble setting mine up. You have to follow a pretty specific sequence to make them work. I started with a clean Windows XP image. I can do that as this is a dedicated computer. Then get on the internet and download NI-DAQmx Base 3.1. Now shut the computer down and install your card. When you restart it should reconize the hardware and install it. Now download NI-DAQmx 8.7.1 and install that. Restart again. Then check your device driver and make sure that 8.7.1 took. The first time I did it I installed 8.7.1 right away and could not get it out. I had to format and reinstall the base then 8.7.1 Ran the first time that way. I have followed this same procedure on the backup computer and it worked first time. Make sure you have all 3 of the DAQ files from the Vixen website downloaded and installed where they say.
    Good Luck
    Iowa - Gods country
    850
    Great . Thanks . Got her going , but NOW , need to figure out how to get my sequence files DOWN to 1.1 without loosing them all .
    jeffathompson Guest
    Open up 1.1 and 2.0 at the same time. Create a new sequence in 1.1. Add the music, background, channels, etc. Now go to 2.0, open up the sequence you want. Select all. then ctrl + c go to the new sequence in 1.1. Select ctrl + v and walla, you just did a cut and paste. I'm guessing that's you only option.
    Iowa - Gods country
    850
    Don't work ... ( knew about CTRL +_ C and CTRL + V )
    Long Island, NY
    5,313
    You have to select the entire cell area in order to copy and paste the data. I have done it and it works. The only pia is manually selecting all the data as the scroll speed is limited.
    Iowa - Gods country
    850
    Sorry ... not sure why , but I just tried again and no luck ( must be doing something wrong )
    Tried using the COPY in the prog ,
    tried CTRL + C
    Even tried copying directly to clipboard .
    no good ....
    Any other suggestions ?
    ( would be SUPER if KC would think about doing a plug in for the new VIXEN for the NI DIO cards since theres a few of us using them --- )
