Results 1 to 10 of 10
Thread: Mounting Pwr supply and controller together
    Silsbee, Tx
    1,099
    Default Mounting Pwr supply and controller together
    I was wondering if a 5v 300watt power supply and E682 or E6804 can be mounted in the same CG enclosure. Such as the CG-1500.
    How have you that run DC power supplies and Pixel controllers mount yours? Together or separately?
    Xenia, Ohio
    1,354
    Default Re: Mounting Pwr supply and controller together
    This area in the Wiki is usually a good place to start.
    http://www.doityourselfchristmas.com...n_Enclosure.29
    [COLOR=#008000]2016 - 5th. year - Over 18,000 channels E1.31 including 350 Channels Renard, Video Projection - XL/NC - On Falcon Player, up to four megatrees.
    [/COLOR][COLOR=#008000]2017 - 6th. year - Moved display to a public park, Over 45,000 E1.31 channels, down to 100 Channels of serial Renard - XLights running on Falcon Player on a raspberry PI.[/COLOR][COLOR=#008000]
    2018 - 7th, year - Still at Shawnee Park, over 52,000 E1.31 channels, down to 96 channels of Renard - [/COLOR][COLOR=#008000]XLights running on Falcon Player on a raspberry PI.
    [SIGPIC][/SIGPIC]
    [/COLOR]
    Randy: X[URL="http://www.xenialights.com/"]enialights[/URL] on [URL="https://www.facebook.com/pages/XeniaLights/420036314711206"]Facebook[/URL]
    Silsbee, Tx
    1,099
    thank you so much. I tend to forget to check the wiki that someone else has already thought of it.
    Sep 2013
    Ontario, Canada
    724
    DIYLED also sells a mounting kit to do this as well.
    http://www.diyledexpress.com/index.p...roducts_id=262
    Silsbee, Tx
    1,099
    From the photo of the power supply I don't see any tabs on it where screws can hold it to a mount.
    Silsbee, Tx
    1,099
    Quote Originally Posted by Electrified3 View Post
    I hate buying any thing without looking at a picture first.
    Brandon, MB, Canada
    380
    I have mine both mounted in a cg-2000 case. I have found it a little tight (depth of box) so I'm going to get a cg-1500 and mount both in that. The power supplies have threads where you can mount them with straps on the side or to a plate on the bottom.
    Jason C
    Jason C
    Nov 2009
    414
    I have 2 controllers where a PS and controller are together in the same CG1500. One of them is for my mega-tree and I needed a second power supply to properly power it, so I have a 2nd enclosure with just a power supply in it, which hooks to the first enclosure with a 4-pin trailer connector.
    Nov 2010
    Livermore, CA
    2,128
    I have a 12v and a 5v power supply (2 supplies) feeding a E682 in the same CG-1500..
    Most of my other controllers have a single 5v power supply with the controller.
    Happy to Show support;
    Xlights/Nutcracker and The Falcon Team [SIGPIC][/SIGPIC]
    Silsbee, Tx
    1,099
    Quote Originally Posted by jcross View Post
    Jason C
    Having threaded holes is something that I could not determine from the photo in the diyledexpress power supply picture. It is always a guess as to what you buying unless there are enough photos describing the item.
