Results 1 to 6 of 6
Thread: Votlage Regulator on LabRat DCSSR
    St.Louis mo
    1,610
    Default Votlage Regulator on LabRat DCSSR
    I have some of these SSR's that i built. I have one in use that is switching 5V, so i soldered a jumper wire as directed in the Wiki. I have others i haven't completed yet. Can i just put the voltage regulator on the board regardless of what i am going to use it for? I may control some 5V item, but may use on 12V too.
    10,283
    Default Re: Votlage Regulator on LabRat DCSSR
    Quote Originally Posted by imbluenote View Post
    You normally do not want to do that - the regulator may become unstable and/or drive the voltage below the 5v due to internal voltage drops required. I think the pads are normal header size spacing - put in a 3x header and put the regulator OR wire on a matching 3x jumper?
    [/SIZE]
    [/COLOR][/I]
  3. Thanks cpcoaster thanked for this post
  4. #3
    10,283
    Actually - if you put in a female header, you might be able to plug in the regulator OR a wire - haven't tried it myself but sounds like an experiment to me!
    [/SIZE]
    [/COLOR][/I]
  5. #4
    St.Louis mo
    1,610
    When i read your first post that is what i thought where you were going. I was thinking of trying it. Thanks for the info and inspiration.
  6. #5
    Jun 2009
    Ottawa, Ontario, Canada
    2,845
    Yes, a header should work just fine. The regulator is purely to provide the 5v to the optoisolator, so there's not fear about drawing too much current through the header.
    Standard Disclaimers apply:
  7. #6
    St.Louis mo
    1,610
    Can I put in the to92 package v reg. and the jumper/socket strip in the to-220 spot and jumper when needed (path of least resistance)?
