Results 1 to 8 of 8
Thread: How to Cut PCB
    jeffathompson Guest
    Default How to Cut PCB
    I've never seen this anywhere so I tried it. This is .030 2 oz copper board. Take a little pressure but cuts like a dream.
    Middle Earth
    2,264
    Default Re: How to Cut PCB
    The big pcb production places use gilloteens as well..
    I have a radial arm sawbench, i use that with a thin high teeth count blade, and it makes a good job as well.
    The other way, is simply to score the board with a knife resonably deeply on both sides, and snap it off.. Works Most times! though sometimes it doesnt.
    [B][FONT=Arial]stell[COLOR="#FF0000"]a[/COLOR][COLOR="#008000"]s[/COLOR][COLOR="#0000CD"]c[/COLOR]apes[/FONT][/B] - LED lighting solutions for the Prosumer, Commercial and Entertainment Industries.
    Doing pixels first since 2009 with [URL="http://www.youtube.com/watch?v=GAt6A98lXQw"]just another megatree.[/URL]
    Follow us on Facebook at [url]www.facebook.com/stellascapes[/url]
    web: [url]www.stellascapes.com[/url]
    Sparks, Nevada
    570
    Quote Originally Posted by jeffathompson View Post
    Jeff,
    I tried this recently and ruined 3 pcb's. I'm not sure why. I have cut smaller greenish colored boards with no problem. The board that shattered was tan or beige in color.
    I use positive etch pre-sensitized boards.
    Brad
    [I][COLOR="Red"]2007:[/COLOR][/I] 32 ch Grinch, [I][COLOR="Red"]2008:[/COLOR][/I] 128 ch Lynx Freestyle, [I][COLOR="Red"]2009:[/COLOR][/I] 128 ch Lynx Freestyle, Four Wireless Lynx Express', 192 Channels, 2 Houses, 4 Gazillion lights, no spare time.I really need to edit my sig pic :oops:
    [SIGPIC][/SIGPIC]
    North Ridgeville, Ohio
    1,558
    I used to use a paper chopper too until mine broke (ironicly while cutting paper). Ever since I've been using a Formica knife to cut PCB's. It has a carbide-tipped blade and is designed score Formica for snapping. I usually clamp the board in a vice, and then score it along the top of the jaws of the vice, on both sides of the board, and then snap it. If I want to make it extra pretty, I dress the edges with a belt sander.
    Don
    Long Island, NY
    7,652
    I have used a carbide ceramic tile blade in a jig saw. I drilled a hole in a piece of plywood that was faced with melamine. I then mounted the jigsaw to the bottom of the board with the blade sticking through the hole. Clamp it to a workbench and it works like a table saw for pcbs. The only issue with using anything besides a guillotine type cutter is the dust. The dust from pcbs is a carcinogen.
    Apple Valley, MN
    3,751
    You only need to score one side, snap it on the edge of a sharp cornered table, flip it over and snap the other side.
    If the rough edge bothers you then after you snap the first side, stand it up and bent the still attached side to something less than 90 degrees and slice the copper with a knife. This is the same way that you cut sheetrock.
    </div>
    Sparks, Nevada
    570
    Thanks Brian. I'm going to try that this week-end.
    Brad
    [SIGPIC][/SIGPIC]
    Oct 2007
    Bundanoon NSW Australia
    263
    Brad,
    The board you are describing sounds like SRBP (resin/paper) and not resin/glass board material. The resin/paper board will shatter easily and lift the copper if you apply a lot of force. From past experience when I have used this type of board it should be deeply scored on both sides. And even then it still might chip. I only use resin/glass boards now.
    Note: SRBP stands for synthetic Resin bonded paper
    Craig.
    Craig
