Results 11 to 16 of 16
Thread: dirkcheap acssr for dc?
    Oct 2008
    San Jose, CA
    10,284
    Default Re: dirkcheap acssr for dc?
    Probably a smaller form factor and hopefully cheaper DC SSR. My "hack" to the dirk cheaps uses a transistor, but that requires customer firmwares on the controllers and also doesn't provide any isolation. I was thinking of trying to experiment with sticking an opto-fet or opto-transitor. Either option would use roughly the same form factor of the DiskCheap. Obviously a much lower current that the full DC SSR (likely around .4A per channel looking at some of the specs), but for a lot of applications, that's probably enough.
    I haven't seen where isolation has been that important for DC controllers - - there are 300+ Ren48LSD's out there representing over 14,000 channels and have never seen a case where the high load power somehow got back through the PIC, back through the RS485 chips and back to the PC - ever. It would be easy to just recreate the output portion of the Ren48LSD - it would still require the flipped outputs, etc as you do today if using a Renard non-SSR controller or even with an Arduino type output. Breadboard out with some cheap transistors and 470 ohm resistors - done...
    [/SIZE]
    [/COLOR][/I]
    Framingham, MA
    527
    I may be thinking a bit too logically (literally, I'm thinking logic gates), but I also had a thought of using a hex inverter (I haven't seen a quad inverter) to flip from sink to source to then drive 4 transistors. However, that would require board space for 4 transistors, 8 resistors, and a 14 pin chip. Might start getting a bit bigger. Not really sure if the inverter thing would work either. Something to breadboard up and experiment with.
    Dan Kulp
    4,928
    FYI: The PIC code has the ability to output its signals using active high or active low modes. Leave out the inverter and change the PIC.
    Oct 2008
    San Jose, CA
    10,284
    You only need four resistors to limit the current to the transistors from the PIC so the circuit could be quite small - smaller than the current dirkcheap AC board for sure.
    [/SIZE]
    [/COLOR][/I]
    Framingham, MA
    527
    Yea, if you look at my pictures and the description and such from my thread at:
    http://www.diychristmas.org/vb1/show...ighlight=dcssr
    that's what I did. However, I'd like to have a solution that doesn't require custom firmware changes. With the RenardPlus boards with the programming headers, it's not a huge deal, but it is a bit more involved with the other boards. Plus, you then need to remember (or record) which channels are source and which are sync and such.
    Dan Kulp
    4,928
    I have a version of the renard PIC code that allows you to change the active high/low setting per channel at run time (download a configuration to the pic over the RS485 interface). Happy to give it to you.
