Results 1 to 10 of 16
Thread: dirkcheap acssr for dc?
    Joliet, IL
    291
    Default dirkcheap acssr for dc?
    Is there any reason you couldn't run 12vdc through a dirkcheap acssr instead of 120vac? As long as the current isn't too high....
    Framingham, MA
    530
    Default Re: dirkcheap acssr for dc?
    I don't think they would shut off without a 0 cross from the AC line.
    However, I have created semi-DC ssr's from the DirkCheaps. See:
    http://www.diychristmas.org/vb1/show...ighlight=dcssr
    Requires a slightly modified firmware for the controller though.
    Dan Kulp
    5,480
    You can't use AC SSRs to control DC for the reason that dkulp stated.
    Joliet, IL
    291
    Ok... I just stared at the schematics and researched further and now I think I understand why.
    I thought the on/off/dimming zero cross was only controlled by (in my case) the Ren64. But, I think I see the difference in the chips that i didn't realize before....
    4,942
    I think you need to take a look at the info in this discussion. It will help you understand the importance of ZC. The Ren 64 does not control ZC. It detects it and reacts to it by refreshing the SSR.
    http://doityourselfchristmas.com/for...des+rectifiers
    SLC, UT
    955
    Hey Dirk, is there a plan to make a DrikCheap DCSSR?
    Nov 2008
    Ottoville ohio
    1,370
    id like a board with just a single DCSSR channel on it. i have alot of dc elements that only need 1 channel and 2 grinchs to run them.
    2012 - The year of the pixels
    21ft tall 12x38ct WS2811 Pixel Megatree - DONE
    5 36ct GECE Pixel Archs - Maybe
    Pixelated roofline with windows - DONE
    Bigger matrix and pixel star - DONE
    Added 1200 pixels, a few strobes, and fast tubes
    Now it just all has to play nicely lol.
    [url]http://www.facebook.com/FiedlerFamilyChristmas[/url]
    [URL="http://www.facebook.com/OhioChristmasDisplays"]http://www.facebook.com/OhioChristmasDisplays[/URL]
    10,284
    Quote Originally Posted by ppohlman View Post
    I'm not clear what's being asked here? The DirkCheap SSR is cheap because it doesn't use a large TRIAC for the output but relies on the smaller TRIAC within the opto to do the work. I don't follow the context of this for DC? Are you just asking for a smaller DC output - something like the Ren48LSD does now? The biggest cost with the DCSSR is probably the MOSFET. Or are you just asking for a smaller form factor?
    [/SIZE]
    [/COLOR][/I]
    Framingham, MA
    530
    Probably a smaller form factor and hopefully cheaper DC SSR. My "hack" to the dirk cheaps uses a transistor, but that requires customer firmwares on the controllers and also doesn't provide any isolation. I was thinking of trying to experiment with sticking an opto-fet or opto-transitor. Either option would use roughly the same form factor of the DiskCheap. Obviously a much lower current that the full DC SSR (likely around .4A per channel looking at some of the specs), but for a lot of applications, that's probably enough.
    Dan Kulp
    SLC, UT
    955
    Smaller form factor, cheaper, no need to power large currents, and ideally able to run power along the network cable. I'd love to only need to run one cable to control and power 4 channels.
