Results 11 to 16 of 16
Thread: Weird Phenomenon
    Jun 2009
    2
    Default Re: Weird Phenomenon
    It happens on new sequences and existing ones. Not using profiles. I'd try 2.1.4 but I don't know where to find it, any suggestions? Thanks.
    3,803
    Don't know anything about a 2.1.4. Here is the link to 2.1.1 http://www.vixenlights.com/download/...%202.1.1.0.zip I would have to dig a bit to find the 2.5 installer. I think it came off of a dev page.
    Feb 2008
    Warminster, PA
    1,709
    Chris
    Nov 2007
    Houston, TX (near Katy)
    969
    Quote Originally Posted by ctmal View Post
    Does this only happen on existing sequences? I you create a new one do you have the issue?
    Also, are you using profiles?
    I would highly suggest upgrading to 2.1.4 if you can. Let me know if the updater fails.
    +1
    I ran this software from 2009 to 2013 before moving to xLights. Check that you have the correct .net framework installed and force the upgrade, if possible. It works perfectly if set up properly. Also make sure that your baud rates match in your harware set up and in Vixen, and they match the baud rates in your controller. I still have 2.1.4 if the upgrade is not available or not posted in the WIKI.
    That's a feature not a bug.
    There's no charge for that.
    Jan 2009
    Eagan, Mn.
    4,073
    Quote Originally Posted by Keith R View Post
    +1
    I had that issue on a fresh install on a new pc and had to find a older version of .net to make it work.
    Dec 2008
    64
    Quote Originally Posted by Captioneer View Post
    Hey pblais, did you ever find a solution to your original problem? I get the exact same thing. Using 2.1.1.0
    Wow... you get the same thing.
    I just learned to live with it but it is annoying. I plan to revamp a lot of stuff this year
    Cheers
    PB
