Results 11 to 20 of 22
Thread: HLS - When to use Library vs CSV
    Key West, FL
    3,630
    Default Re: HLS - When to use Library vs CSV
    Make sure you hit the SAVE button before trying.
    Then if things don't work as expected -- you simply undo by going back.
    Joe
    6,010
    This thread should be a Sticky .
    Aug 2013
    Prairieville, LA
    821
    I have an LOR sequence from last year that I imported into HLS and the only way I know to setup the channels is to go into channel manager, PP channel setup, etc for my six arches from last year one by one, which is not all that hard but is a bit time consuming, along with adding my new megatree channels for this year. Can I combine an LOR import into HLS with along with an existing channel setup using the "create an image... start new sequence from saved image..." method shown in these posts??
    Thanks in advance!
    Key West, FL
    3,630
    Dan
    The Library process was developed to handle just your case.
    Remember --- Library Layout MERGE is based on channel names --- so as long as the NEW LOR file has the same names as a previously convert LOR file to which HLS channels were added --- you are good to go.
    Step 1. Make sure you have saved a Layout into a Library from a previous LOR conversion to which you have added your additional HLS channels.
    Step 2. Start your NEW sequence -- and import your LOR sequence.
    What you should haave now is a HLS sequence based on your LOR sequence.
    Step 3. Use the Library to import the Layout you want.
    I would elect to update everything --- that way changes you made to your LOR channels -- like Universe Number Number and Preview Group/Channel --- will all be updated.
    Once the Layout import is complete -- you should be good to go.
    Joe
    Jan 2014
    Massachusetts
    22
    Hi Joe,
    When I did an export to CSV, my color is all zero. Everything else worked fine, these are LOR channels. Should I have color?
    Rob
    Key West, FL
    3,630
    Color is zero for RGB channels -- it is only meaningful with incans and leds because it says what color they are for the Editor's grid display.
    Are your channels RGB?
    Joe
    Key West, FL
    3,630
    I just ran a test and it looks like you found a bug.
    Keep on me for the next day or two --- got life things I'm doing -- remind me Sat and I will fix with a new release.
    Joe
    Jan 2014
    Massachusetts
    22
    No they are not RGB, they a regular leds.
    Guid Current Name Universe Channel Color RGB Dimming Curve DMX_Group GRB DMX_Fixed OutputOrder PrevGroup PrevNumber PrevX PrevY New Name Change This
    G2017156552179318960 Window 1F Rd 01.03 1 3 0 0 0 0 0 0 4 47 0 0 Window 1F Rd 01.03 1
    G2017156552179319052 Window 1F Gr 01.04 1 4 0 0 0 0 0 0 4 48 0 0 Window 1F Gr 01.04 1
    G2017156552179319144 Window 2F Rd 01.05 1 5 0 0 0 0 0 0 4 49 0 0 Window 2F Rd 01.05 1
    G2017156552179319235 Window 2F Gr 01.06 1 6 0 0 0 0 0 0 4 50 0 0 Window 2F Gr 01.06 1
    G2017156552179319328 Window 3F Rd 01.07 1 7 0 0 0 0 0 0 4 51 0 0 Window 3F Rd 01.07 1
    G2017156552179319421 Window 3F Gr 01.08 1 8 0 0 0 0 0 0 4 52 0 0 Window 3F Gr 01.08 1
    G2017156552179319514 Window 4F Rd 01.09 1 9 0 0 0 0 0 0 4 53 0 0 Window 4F Rd 01.09 1
    G2017156552179319607 Window 4F Gr 01.10 1 10 0 0 0 0 0 0 4 54 0 0 Window 4F Gr 01.10 1
    G2017156552179319699 Window 5F Rd 01.11 1 11 0 0 0 0 0 0 4 55 0 0 Window 5F Rd 01.11 1
    G2017156552179319790 Window 5F Gr 01.12 1 12 0 0 0 0 0 0 4 56 0 0 Window 5F Gr 01.12 1
    G2017156552179319880 Window 6F Rd 01.13 1 13 0 0 0 0 0 0 4 57 0 0 Window 6F Rd 01.13 1
    G2017156552179319972 Window 6F Gr 01.14 1 14 0 0 0 0 0 0 4 58 0 0 Window 6F Gr 01.14 1
    G2017156552179320064 Window 7F Rd 01.15 1 15 0 0 0 0 0 0 4 59 0 0 Window 7F Rd 01.15 1
    G2017156552179320156 Window 7F Gr 01.16 1 16 0 0 0 0 0 0 4 60 0 0 Window 7F Gr 01.16 1
    [/SIZE][/SIZE]
    Key West, FL
    3,630
    As I posted just above yours --- HLS's current CSV is not exporting Color -- I will address this weekend.
    Joe
    Jan 2014
    Massachusetts
    22
    Sorry I must have been typing and I missed that post. Thanks for all the support.
    Rob
