Results 1 to 5 of 5
Thread: Preview File
    Hamilton, OH
    502
    Default Preview File
    As a result of adding additional channels this year and re-configuring my old controller layout, I needed to reorder channels in my Manage Raw Channels list. Initially I just added the channels, but I decided I should go back in and reorganize the channels list. Upon doing so, I guess this reconfigured the preview group and preview number. When I play the sequence and view the preview the channels no longer are assigned to the previous vector. I went in to the edit preview and reassigned all of the vectors to the appropriate channel. This took a great deal of time. I loaded my next sequences and started the process all over. Rather than do this for each sequence, is there a way to copy the preview file and rename it to the next sequence instead of reassigning the vectors for each song? I don't even know if there is a "preview file," but I thought I would ask.
    [url]http://www.facebook.com/LightsOnGildayCourt[/url]
    6,214
    Default Re: Preview File
    After adding your channels your sequences will need updating of their preview Group # and Preview # that is all .
    as long as they match your previews designation all is happy . the preview is not associated to a particular sequence .
    Though you may have created it in a particular sequence . this concept took a bit to sink in for me .
    One thing to remember is if you have pixel planes in your sequences you will need to assign their channels in the pp editor .
    good luck .
    Huntsville, AL
    3,644
    Let's lay out some foundation.
    HLS is designed so that your design/editing AND Preview are NOT tied to physical hardware.
    There are three (3) different processes in HLS: Edit, Preview, and Output. Note ... once you design a PREVIEW ... That Preview is available to all sequences -- no need to recreate it each time.
    Your job is to design a sequence -- THAT is the Edit process.
    Now - if you want to view that process in the Preview process - you have to create and manage a link between the two. THAT link is the Group and Group Channel data located and managed in Raw Channels (far right side of Grid).
    If you want to Output your sequence --- you create THAT link (Edit to Output) using Universe and Universe Channel. Universe can be modified in Raw Channels or in Ready Channels for Output. HLS automatically assigns Universe Channels for you when you Ready Channels for Output.
    Plus side of this concept: You can create sequences and Preview sequences without knowing anything about what hardware you will use to drive physical lights. Changes to your physical display (controllers, Incans, RGB, Pixels, Renard, E131) have NO impact of your Preview.
    Negative side -- you have two different output type processes that have to be maintained.
    Now --- knowing all of that --- there is nothing you could have done in your OUTPUT side that affected your Preview --- unless you started to play with the Group and Channel numbers.
    Whatever you did --- you got it goofed up ... OR .... you added all kinds of new channels and now you want to send THAT new information to Preview and OUTPUT. How do you do that? .....
    There are videos on each of those topics ... so lets assume you've done that and have gotten your sequence properly setup -- Preview works and Output works. BUT .... you have several other sequences that must be updated to reflect your changes -- How do you do that?
    Two ways .... Library and CSV.
    Both of these match CHANNEL names ... so beware ... in your adding and changing of channels --- if you muck around with the channel names --- you loose the ability to easily update other sequences.
    Library: You can Save a copy of your Sequence's Layout to the Library. The Library Layout captures a channels Name, Output Universe, Output Channel, Preview Group, Preview Group channel, and other information. If you elect to edit a New/Different sequence -- you can IMPORT a saved Library Layout into it. The Import process will match channel names -- when it finds a match --- it updates the Output and Preview related data fields. Library Import will also ADD new channels to your sequence that were NOT found to exist.
    So if this year you added a bunch of Pixels .. Set up your Preview and Output links described above, save the layout to the Library and use the Library Import process to update ALL of the other sequences you use.
    That's Library.
    Now CSV. In Raw Channels --- there is a button to export a list of channel related data and save that data in a CSV file. For those of you that don't know, a CSV file is a comma delimited text file that can be opened and modified by Excel.
    Open the CSV file in Excel and take a look. Much of the same data that is stored in the Library is in the CSV file --- with one exception ... there are two Channel Name columns and a Update column.
    The second channel name column will hold the NAME you want to change the Channel's current name to.
    The Update column is a numeric that contains a zero in each cell. YOU make that cell a ONE --- and HLS will modify ONLY THAT Channel when you Import a CSV.
    So what's the difference between Library and CSV ....
    Library will update a channel when the name matches and ADD channels when the name is not found.
    CSV will only update specific channels and WILL NOT ADD channels. CSV also allows you to CHANGE channel names. So if you previously mucked around and changed channel names and now they don't match the channel names in you other sequences, CSV allows you to match the current mucked up name and then replace it with the Wanted Name.
    Both the Library and CSV files are designed to help you UPGRADE you sequences each year (adding or changing physical hardware) with as little work as possible.
    Those of you that convert old Vixen sequences and then upgrade your sequence with new hardware should study and become familiar with the use of both the Library and CSV files ... they greatly SPEED up the changes.
    Hope that helps.
    Joe
  4. Thanks cnbales thanked for this post
  5. #4
    Hamilton, OH
    502
    Joe.
    Thank you for the detailed explanation.
    I did save my new channel layout to the library. My assumption is that I can only use the new layout when creating a new sequence and that I can't change a channel layout from the library once I have already selected a channel layout and started work on that sequence. If I am wrong about this please let me know. This was my preferred method, but I was not able to go into an existing sequence and load the new layout when I tried.
    Therefore, I attempted to use the CSV import and was unsuccessful. Here were my steps:
    1. From an existing sequence I created a CSV export file. Upon completion, I verified that the csv file had the correct channel layout that I wanted to import into a different sequence.
    2. I opened the different sequence, selected Manage Channels, selected Import CSV and Update Raw Channels. I checked all of the boxes and during the first attempt selected Import Based On Guid. My second attempt I selected Import Based on Current Name Matching. After each attempt HLS had to save and shut down. Upon restarting HLS and going into the sequence I attempted to load the new raw channels in it did not work. What am I doing wrong?
  6. #5
    Hamilton, OH
    502
    Never mind... I got it. I took the risk of loading a new layout from the library on an existing sequence. HLS gave me a warning that I should only do this if converting from a Vixen sequence. I only had a couple hours into a particular sequence and thought I would take the risk of proceeding. The risk paid off! I checked with other sequences and everything is matching up perfectly. Thanks Joe and angus!
