Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: SSR's explained
    Delaware, OH
    4,430
    Default Re: SSR's explained
    Very important point that should be noted in your illustration!!!
    The 'tab' that connects the 'hot' side of the outlets needs to be broken off.
    It is made to be bent back and forth for removal.
    Once that is done, I think it would be an excellent addition to the wiki.
    Let me know if you need me to add it.
    148
    Thanks for the answer to my "how to wire it up" question.
    I tried to log in/create an account and could not.
    You are more than welcome to post the picture on the wiki if you
    think it will help someone.
    Sparkey
    01.19.09
    I changed the picture to point out removal of the tab.
    Last edited by Sparkey; 01-19-2009 at 02:15 AM. Reason: change in picture by request
    Ocoee, FL
    1,637
    To: Sparkey and all newbies,
    Remember you can also use the SSR in "The Pod" configuration. Still same concept for the wiring but doesn't limit you to buying this type of hardware. The Pod would simply use your SSR in an enclosure with a power cord supplying power and 4 extension cords with female ends hanging out.
    For example of POD config. see page 1 of this thread.
    North Ridgeville, Ohio
    1,558
    He did mention this between the 4th and 5th pictures.
    You must break off the jumper tab on the "hot" side of the outlets so you have 4 separate outlets
    Don
    Apple Valley, MN
    3,765
    Quote Originally Posted by Sparkey View Post
    Sparkey
    01.19.09
    By default, you will not have access to modify the Wiki. Contact Brian (Macrosill) and ask if you can be added.
    </div>
    Indiana, USA
    229
    Another question: what does the control input to a dimming SSR look like? If I have a 0-5V PWM output, would it be a simple matter to control an SSR with that, or would I need signal transmogrification of some sort? Or is there a better solution to converting 0-5V PWM to dimming light control? Thanks.
    Feb 2010
    Neighbor of Manny "PACMAN" Pacquiao
    87
    Very Very Informative ...
    and Many Thanks to Sparkey ... now i know hows SSR works ... lol
    thanks a lot ..
    Regards,
    Rey - Philippines
    Jan 2010
    New Zealand
    256
    Can someone please tell me what the difference between an SSRez and an SSRoz board is? Or where to find descriptions of the boards?
    Frank
    Dec 2008
    3,923
    Not a great deal of difference, but I have both so I'll try...
    The SSRez is the newer and has some differences that I think are most important:
    1. Mounts perfectly in our coming enclosure (TA-200)
    2. Has on-board neutrals so it removes need for tieing neuturals together with a WireNut
    3. It's a bit larger than the SSRoz.
    There are probably others, but this is my experience.
    The wiki contains info on both of them.
    California
    2,512
    hey wow never read this thread before...great simple way to put it very good thank you !! love the ssr in the outlet box such a cheap and yet effective way to do that
    [B][I]MY Favorite Links:[/I][/B]
    [URL="http://doityourselfchristmas.com/wiki/index.php?title=Main_Page"][COLOR="red"]Christmas Wiki[/COLOR][/URL] | [URL="https://www.facebook.com/dancingofthelights"][COLOR="red"]My Facebook Page[/COLOR][/URL] | [URL="https://www.calvertimage.com"][COLOR="red"]My Website[/COLOR][/URL]
    [B]2013 Show[/B]
    1 - E682 not in use
    248 - Renardss Dimmable channels
    144 - Renard48lsd channels
    272 - channels in use
    40,000 lights synchronized and static
    50% assembled and displayed
