Results 11 to 20 of 34
Thread: Audacity Beat and Bar Track Addin for Vixen 2.5
    Oceanside, CA
    2,363
    Default Re: Audacity Beat and Bar Track Addin for Vixen 2.5
    Quote Originally Posted by teberle View Post
    I just tested the the addin that I wrote for 2.5. It works fine in 2.1, just add the dlls into the addins directory and you should be able to use it.
    Great news! This was going to be my first question when I saw this was posted for 2.5.
    I'll give it a shot tonight in V2.1 and V+!
    Oceanside, CA
    2,363
    Either I picked a bad song, or I'm not doing something right. I just get very random beat marks all over the place.
    I've never used a beat/bar marker in any sequencer before, so is there any good "howto" on what to do with this? I was hoping it would give me good timing marks for a song quickly/easily, but when previewing the beats, it appears to be all but random.
  3. Likes sjswanner liked this post
  4. #13
    Broken Arrow, Oklahoma
    627
    Quote Originally Posted by Materdaddy View Post
    I assume that you loaded the Vamp plugins and have Audacity working. so here is how it would work.
    Here is a wiki page no how to create a label track in Audacity, it is for HLS but this part is the same.
    Here is some more information on how to do the same
    Here is how I do it.
    Open mp3 in audacity and use analyze -> bar and beat tracker: beats...
    Select 4 beats/bar and hit ok
    Labels are created and track name is "Bar and Beat Tracker: Beats...
    I click file-> export labels
    I'm then given a file save window where it automatically wants to save the file as labels.txt
    Once this is done I open up Vixen and load the sequence that I want.
    I select the Addin 'Audacity beat Track'
    Select the type of beat 'Bars or Beats'
    Import the Beat Marks.
    Set the Events/Beat to 8 then select Calculate BPM.
    I then see the Marks on the right, which is just an indicator that they were loaded.
    I then select to either Update the Event Period to match the calculated one, or leave it alone.
    I then select to Insert Beats on the number of channels that are indicated.
    I then select the channels that I want for the beats
    Select Okay and the sequence is updated.
    I have attached a picture of the Addin and a picture of a sequence with the beat tracks.
    If this doesn't work, send me you mp3 and sequence and I will see what I come up with.
    [SIGPIC][/SIGPIC]
  5. #14
    627
    I have made some updates to the Addin to keep it in sync somewhat with what we are doing on V3.
    I changed the following:
    1. Added the ability to use the standard Audacity beat finder files.
    2. Flattened the VAMP beat track into a single track so that all beats are on one channel
    3. I bring in the sequence event setting so that the user can see what is currently selected and if they want to use the calculated event setting
    4. You no longer selecte multiple channels for the beats just a single channel.
    5. The addin will use the calculated event period if you select 'Update Event period' or it will use the sequence setting.
    I know that the beats may get off in time since a calculation is being performed on where to insert the beat in the sequence based on the time of the beat and the event ms timing, but for the most part it is pretty close.
    Let me know if anybody needs it to do something different, I know it is helping me on my sequencing.
    Attached Files Attached Files
    [SIGPIC][/SIGPIC]
  6. #15
    Nov 2012
    Valdese NC
    32
    Does anyone know where to download the QM vamps?? All the download links i have found are dead
  7. #16
    627
    Quote Originally Posted by twb5150 View Post
    Download them here
    [SIGPIC][/SIGPIC]
  8. #17
    Nov 2012
    Valdese NC
    32
    Thanks teberle but when i click the "Download" link it takes me here http://isophonics.net/QMVampPlugins then when i scroll to the bottom to download the windows version it never loads says problem loading
  9. #18
    627
    I attached the windows version that I have.
    [SIGPIC][/SIGPIC]
  10. #19
    Nov 2012
    Valdese NC
    32
    Thanks teberle
  11. #20
    Nov 2013
    Bloomfield, NJ
    113
    Would this be something good for a newbie who is getting confused doing beat tracks?
