Results 11 to 20 of 25
Thread: converting older versions of .vix files
    Sparks, Nevada
    570
    Default Re: converting older versions of .vix files
    Quote Originally Posted by Macrosill View Post
    If you have Vixen version 1.xxx sequences and would like to convert them to 2.xxx sequences you are in luck. KC has included a conversion file in the 2.xxx install. This is a self deleting file. It will run the 1st time a new install is opened and then delete itself after the conversions are completed. I do not recall the name off hand but will find it for you shortly. Wayne advised me the file name is prepare.exe. Now onto the conversion.
    1. Download and install Vixen 2.xxx.
    2. Once installed browse into the sequences folder of the new installation utilizing Windows Explorer.
    3. Copy and paste your 1.xxx sequences into the 2.xxx sequences folder. Take notice of "copy and paste", this will ensure you do not lose any data in the event something goes wrong with the conversion process.
    4. Copy and paste your music files from the Music folder of Vixen 1.xxx to the Audio folder of Vixen 2.xxx.
    5. Right click on the Vixen 2.xxx .exe icon, the reindeer head, and "Send to Desktop". This will place a shortcut onto your desktop.
    6. Close all the open windows.
    7. Open Vixen 2.xxx by double clicking the reindeer head you just placed on the desktop.
    8. Sit back and let Vixen convert your files.
    9. Enjoy your newly converted sequences by opening them and let them run.
    I was not going to use any of last years sequences when I updated to 2.XX, but now I'm running short on time. I'm thinking about converting one or 2 of my 1.XX .vix files from last year. I already have my profile built in 2.5 and my intro sequence almost complete. Question is, can I convert the older 1.XX .vix files without loosing the new .vix file and profile?
    Brad
    [I][COLOR="Red"]2007:[/COLOR][/I] 32 ch Grinch, [I][COLOR="Red"]2008:[/COLOR][/I] 128 ch Lynx Freestyle, [I][COLOR="Red"]2009:[/COLOR][/I] 128 ch Lynx Freestyle, Four Wireless Lynx Express', 192 Channels, 2 Houses, 4 Gazillion lights, no spare time.I really need to edit my sig pic :oops:
    [SIGPIC][/SIGPIC]
    Long Island, NY
    7,656
    As far as I know and can understand what your intentions are you can do so if the files have different names as they need to be in the same folder. Then you will need to associate the converted sequences to the new profile.
    Sparks, Nevada
    570
    So if I understand your original post, the conversion routine deletes itself, therefore I would have to delete Vixen and download a new version? Then run the conversion.
    Brad
    [SIGPIC][/SIGPIC]
    Spencer Iowa
    1,236
    Vixen is looking for a file called "prepare.exe"
    Copy it from the original zip or download a new zip install file.
    Place the prepare.exe file in the base directory (the same one as vixen.exe)
    When you start vixen any 1.0 sequenceds will be converted to 2.0.
    Existing 2.0 files will not be modified.
    Joel
    Sparks, Nevada
    570
    Got it.
    Thanks for the help guys.
    Brad
    [SIGPIC][/SIGPIC]
    Jul 2009
    3
    HI everyone. I've been also having troubles while converting my vix sequences to use them with the new version of vixen. I've done all what you've say before, but I can't solve the problem. I'm running vixen in windows xp, and have upgraded to the lastest version of it. When I run the program, the prepare thing happens, (it does't say any clue of what sequences has converted) but says it has finished. When I try to open a sequence, it apears an error message, which details are the following:
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.NullReferenceException: Object reference not set to an instance of an object.
    at Vixen.EventSequence.LoadFromXml(XmlNode contextNode)
    at Vixen.EventSequence..ctor(String fileName)
    at StandardSequence.StandardSequence.Open(String filePath)
    at Vixen.Form1.OpenSequence(String fileName)
    at Vixen.Form1.openALightingProgramToolStripMenuItem_ Click(Object sender, EventArgs e)
    at System.Windows.Forms.ToolStripItem.RaiseEvent(Obje ct key, EventArgs e)
    at System.Windows.Forms.ToolStripMenuItem.OnClick(Eve ntArgs e)
    at System.Windows.Forms.ToolStripItem.HandleClick(Eve ntArgs e)
    at System.Windows.Forms.ToolStripItem.HandleMouseUp(M ouseEventArgs e)
    at System.Windows.Forms.ToolStripItem.FireEventIntera ctive(EventArgs e, ToolStripItemEventType met)
    at System.Windows.Forms.ToolStripItem.FireEvent(Event Args e, ToolStripItemEventType met)
    at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEven tArgs mea)
    at System.Windows.Forms.ToolStripDropDown.OnMouseUp(M ouseEventArgs mea)
    at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at System.Windows.Forms.ScrollableControl.WndProc(Mes sage& m)
    at System.Windows.Forms.ToolStrip.WndProc(Message& m)
    at System.Windows.Forms.ToolStripDropDown.WndProc(Mes sage& m)
    at System.Windows.Forms.Control.ControlNativeWindow.O nMessage(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Loaded Assemblies **************
    mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400)
    CodeBase: file:///c:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
    Vixen
    Assembly Version: 2.1.1.0
    Win32 Version: 2.1.1.0
    CodeBase: file:///C:/Documents%20and%20Settings/Usuario/Escritorio/Vixen%202.1.1.0/Vixen.exe
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
    System.Drawing
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Xml
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
    fmod
    Assembly Version: 2.1.0.0
    Win32 Version: 2.1.0.0
    CodeBase: file:///C:/Documents%20and%20Settings/Usuario/Escritorio/Vixen%202.1.1.0/fmod.DLL
    AnalogSpectrum
    CodeBase: file:///C:/Documents%20and%20Settings/Usuario/Escritorio/Vixen%202.1.1.0/AddIns/AnalogSpectrum.DLL
    CometConversion
    CodeBase: file:///C:/Documents%20and%20Settings/Usuario/Escritorio/Vixen%202.1.1.0/AddIns/CometConversion.DLL
    DMXAddIn
    CodeBase: file:///C:/Documents%20and%20Settings/Usuario/Escritorio/Vixen%202.1.1.0/AddIns/DMXAddIn.DLL
    MIDIReader
    CodeBase: file:///C:/Documents%20and%20Settings/Usuario/Escritorio/Vixen%202.1.1.0/AddIns/MIDIReader.DLL
    Prop1SeqGen
    CodeBase: file:///C:/Documents%20and%20Settings/Usuario/Escritorio/Vixen%202.1.1.0/AddIns/Prop1SeqGen.DLL
    Prop2SeqGen
    CodeBase: file:///C:/Documents%20and%20Settings/Usuario/Escritorio/Vixen%202.1.1.0/AddIns/Prop2SeqGen.DLL
    RemoteClient
    CodeBase: file:///C:/Documents%20and%20Settings/Usuario/Escritorio/Vixen%202.1.1.0/AddIns/RemoteClient.DLL
    RGBLEDAddIn
    CodeBase: file:///C:/Documents%20and%20Settings/Usuario/Escritorio/Vixen%202.1.1.0/AddIns/RGBLEDAddIn.DLL
    Spectrum
    CodeBase: file:///C:/Documents%20and%20Settings/Usuario/Escritorio/Vixen%202.1.1.0/AddIns/Spectrum.DLL
    WattMeter
    CodeBase: file:///C:/Documents%20and%20Settings/Usuario/Escritorio/Vixen%202.1.1.0/AddIns/WattMeter.DLL
    Waveform
    CodeBase: file:///C:/Documents%20and%20Settings/Usuario/Escritorio/Vixen%202.1.1.0/AddIns/Waveform.DLL
    LedTriksUI
    CodeBase: file:///C:/Documents%20and%20Settings/Usuario/Escritorio/Vixen%202.1.1.0/Plugins/UI/LedTriksUI.DLL
    LedTriksUtil
    CodeBase: file:///C:/Documents%20and%20Settings/Usuario/Escritorio/Vixen%202.1.1.0/Plugins/Output/LedTriksUtil.DLL
    StandardScript
    CodeBase: file:///C:/Documents%20and%20Settings/Usuario/Escritorio/Vixen%202.1.1.0/Plugins/UI/StandardScript.DLL
    ScriptEngine
    CodeBase: file:///C:/Documents%20and%20Settings/Usuario/Escritorio/Vixen%202.1.1.0/ScriptEngine.DLL
    StandardSequence
    CodeBase: file:///C:/Documents%20and%20Settings/Usuario/Escritorio/Vixen%202.1.1.0/Plugins/UI/StandardSequence.DLL
    TriggerResponse
    CodeBase: file:///C:/Documents%20and%20Settings/Usuario/Escritorio/Vixen%202.1.1.0/Plugins/UI/TriggerResponse.DLL
    ************** JIT Debugging **************
    To enable just-in-time (JIT) debugging, the .config file for this
    application or computer (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
    <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the computer
    rather than be handled by this dialog box.
    Any ideas of what could it be?
    Thanks since now.
    Nicolas
    Ahwatukee (Phoenix), AZ
    1,994
    One thing to note:
    With the converting of vixen sequences, you will need to convert as follows:
    Vixen 1.xx.xx --> Vixen 2.0.xx --> Vixen 2.1.xx
    If you have Vixen 1 sequences, they need to be converted in Vixen 2 before they can be opened in Vixen 2.1.
    Jul 2009
    3
    thanks for your help, now I could convert my sequences.
    Amarillo, Tx
    241
    Smile Re: converting older versions of .vix files
    good information Frank thanks again
    Jul 2009
    shenzhen
    7
    I really dont know what are you doing .I am a poor guy.
