Results 1 to 2 of 2
Thread: Proper way to load a shared sequence
    Tustin, CA
    2,143
    Default Proper way to load a shared sequence
    OK, maybe I'm just missing something but when you have just the .hls file what it the correct way to load it in and connecting it to the music file?
    6,010
    Default Re: Proper way to load a shared sequence
    Not sure exactly , but you can try this if you know the song it was created with .
    create a new sequence and use the song it requires .
    this may create all the needed files . save and close hls .
    goto the hls folder and copy the files from the new seq folder to the one you need the files for .
    you will need > ( song name ) .pcm << most importantly
    I don't know if you will be s.o.l without the effects etc .
    worth a try though .
