Results 11 to 20 of 23
Thread: W5500 driver
    Sep 2009
    Omaha, Ne
    3,147
    Default Re: W5500 driver
    Thanks for thinking of me, its not like I wrote the W5200 driver or something. ;)
    Had I had your email address handy you would have been CC'ed. LOL. Actually figured you might have already knew!
    1,216
    Still requires a lot of discrete components. 20+ resistors, 20+ caps, crystal, inductor, transformer. The transformer used in the 550IO is pricey. Wiznet's reference design varies somewhat from the transformer manufacturers data sheet also. A neat project might be a 5500-based pin-compatible replacement for the WIZ820IO.
    The Sandevices E680/E681/E682 Pixel Controllers, part of the[SIZE=3] [COLOR=red]P[/COLOR][COLOR=orange]I[/COLOR][COLOR=blue]X[/COLOR][COLOR=lime]E[/COLOR][COLOR=magenta]L[/COLOR] [COLOR=red]P[/COLOR][COLOR=lime]R[/COLOR][COLOR=blue]O[/COLOR][COLOR=red]J[/COLOR][COLOR=magenta]E[/COLOR][COLOR=cyan]C[/COLOR][COLOR=red]T[/COLOR]
    [URL="http://www.sandevices.com"]www.sandevices.com[/URL][/SIZE] <-email jim at
    WI
    2,611
    Finally heard back from wiznet today about the differences between the W5200 and new W5500. See attachment.
    Attached Files Attached Files
    1,216
    I'm not sure I understand the new SPI protocol.
    WI
    2,611
    Quote Originally Posted by jstjohnz View Post
    Yeah I'm trying to wrap my head around the "Block Select Bit" portion. It seems that its just a shortcut to get to the registers for a given socket. So I think the deal is you select the Block [socket] then you offset into memory for the register you want.
    1,216
    How do you control the transfer size? Just stop sending clocks when done? And is the bit order reversed?
    WI
    2,611
    Seems like there are two options, fixed and variable. For variable it knows to stop when the chip select pin state changes.
    That seems to be true.
    Ugh I wish they would stop reinventing the wheel every time they release.
    WI
    2,611
    I have a dev board on the way.
    2
    Does somebody have a working W5500 driver (or maybe working spi read/write functions)? Im trying to get a webserver with W5500 working. Im also using an atxmega128a1 for that.
    Nov 2012
    Cary, NC, US
    1,214
    I have a working W5500 server for MSP430. With few small changes, it can be used on other platforms.
