Results 1 to 10 of 15
Thread: Ren XC - assembly problem
    Pilot Mountain, NC
    611
    Default Ren XC - assembly problem
    The new BOM listed a 25v capacitor. I just received this part and it does not fit on the board. The holes are too small. Also the capacitor is too big around to fit close to the board. It would need to be left up to go over the diodes D3,D4 and possibly U3 & U4.
    All that said, what is the suggestion? Do I have the correct part?
    Mooresville, NC
    5,063
    Default Re: Ren XC - assembly problem
    hmmm, I thought it was a 16v part, but the BOM does list a 25v cap. Well, I see two options, one is wait and see what Phil thinks about the 16v cap. ( that one should fit well) or.... you will have to drill the board out and leave the cap up off the board to clear the diodes and to be able to solder the + side of the cap, which is on the top layer. I would wait to see what Phil says first though.
    4,125
    It doesn't need to be 25V, I'm not sure how that got in there. A 16V part is fine, and I need to change the BOM.
    Pilot Mountain, NC
    611
    Thanks guys!
    Pilot Mountain, NC
    611
    asked in different forum
    Oct 2007
    Rockhampton, QLD' Australia
    31
    I tag a little to this thread if thats okay?
    Does anyone have an Assembly how-to or is it straight forward?
    Sometimes things appear harder then what they are, don't give up, just try harder..
    Pilot Mountain, NC
    611
    Since there are no optional parts, just use the BOM posted in the Wiki. It lists all the parts, and where they go.
    http://www.doityourselfchristmas.com...Renard64#BOM_2
    Jul 2007
    SW Florida
    221
    Phil, I have some extra capacitors from the Renard XB I didn't use. These are 16volt. will they work on the Renard XC? The Mouser part # is 140 XRL16V1000-RC. Thanks for any help. Jerome
    4,125
    No, they are way too small.
    Jul 2007
    SW Florida
    221
    So it is my understanding that the 25volt Capaciter that was in the BOM that I accidently got will work if it can be made to fit on the board. Is this correct? Thanks, Jerome
