Results 1 to 10 of 18
Thread: Help sourcing IR LEDs
    Oceanside, CA
    2,363
    Default Help sourcing IR LEDs
    I'm looking to outfit a DIYC Flood for blasting my guests with 940nm-950nm IR. This is to have them bring their own Disney® Glow With The Show™ hats to my display and take control of them. I have a couple of those floods un-built from a previous group buy so I already have constant current LED drivers and the rest of the BOM. I simply need to find some 5mm Piranha Style Super Flux LEDs that are 940-950nm.
    I tried a few google searches and the only ones I could find were either 850nm which won't work, or minimum order qty of 2k+.
    I know some of you out there probably have some places for me to check, especially those of you running stores/group buys.
    Thanks in advance for the tips!
    Las Vegas, Nevada, U.S.
    2,156
    Default Re: Help sourcing IR LEDs
    Well you can always put 2 or more ones in each slot.
    This one has a 30deg angle. The ir led seam to suck down quite a bit of power though so i am not sure they will work.
    http://www.mouser.com/ProductDetail/...UUGOuZxKXSs%3d
    Projects:
    Videos
    Malden MA
    991
    There are quite a few higher power 940nm IR LEDs out there (1W - 20W are easy to find). They will need some changes to the power supply to drive.
    /mike
    Jun 2009
    Ottawa, Ontario, Canada
    2,848
    I thought he we looking for Piranha style, which are the 4 pin square devices. (I opted to create a small daughter card that contains 15 standard 5mm leds, and uses a resistor for the constant current source. So far so good). I can post gerbers if anyone else wants to try.
    Standard Disclaimers apply:
    Sep 2009
    Omaha, Ne
    3,154
    I looked for some to make a IR Flood out of a DIYC Flood board for a CCTV camera, but could not find any that were not in the visible range. Let me know if you find anything.
    Oct 2012
    291
    Vishay has one of the best product selections. If your looking for a 4 leg thru hole?
    http://www.vishay.com/ir-emitting-di...product-82564/
    Oceanside, CA
    2,363
    Quote Originally Posted by Utimgr View Post
    Mouser just added these... are these drop-in replacements to fit the DIYCFlood?
    Should I get a different LED driver?
    I'm going to place a mouser order tomorrow for these and hopefully get myself a GwtS transmitter this year after all!
    Oceanside, CA
    2,363
    How hard would your solution be to perfboard? I might go this route since it's probably too late for me to get a PCB made.
    Jun 2009
    2,848
    Easy Peasy... the schematic is no different than the MightyMini LED flood. Several (three) leds in series with a resistor. Put a few of those in parallel, and toss in a MOSFET to trigger/control the mess.
    Oceanside, CA
    2,363
    Recommendation on a .1" spaced MOSFET that would go on perfboard easily and work well for this?
