Results 11 to 20 of 38
Thread: Getting the hang of Vix 3, but having tons of trouble
    May 2010
    ottawa , ontario, Canada
    1,752
    Default Re: Getting the hang of Vix 3, but having tons of trouble
    Quote Originally Posted by gizmohd View Post
    We are gearing up for a release in the next few days that should fix these issues. If you want to test it, take a look in http://www.vixenlights.com/builds for the 3.08.13 dev build. That is the latest release candidate. And let us know if it fixes your performance issues.
    Sent from my SGH-T889 using Tapatalk 2
    i try it and still have bug
    cheer
    Sheboygan, WI
    1,712
    It's worse for me. Now I get no preview.
    I have a blank preview window that has to following:
    FPS 21
    Points 2803
    Pixels 0(rest unreadable)
    Render Time: Constantly changing
    Max Render: 75
    Average Render : Constantly changing
    Jan 2010
    Jacksonville, FL
    413
    Two things,
    it looks like you are using the new Direct2D prevew... (which is good., but your system may not like it, some dont), when you edit your preview, you can select the Performance drop down and change it to use the GDI preview (original). If that clears it up for you great... If not,
    can you send me your Error.log file? I would guess that something is happening under the hood that V3 doesnt like, and knowing what that is will be a big help
    Sheboygan, WI
    1,712
    Two things,
    No go. Now it's a lovely mauve color.
    Attached Files Attached Files
    Jan 2010
    Jacksonville, FL
    413
    The good news is.... I've replicated the error....
    Can you go into the 'Configure Preview' screen and make sure you have a background set... my mauve color came when no background image was set....
    if one IS set... then make a small change.. and save the preview.. THen before you do anything else... completely exit out of V3... and restart it... if all else goes well, then the preview screen should show the correct image...
    Sheboygan, WI
    1,712
    Ok, I added a picture to the preview and that part is fixed. I ran some simple tests with wipes and it's looking very promising now. I will beat it up this weekend and report back.
    Thanks!
    Jan 2010
    Jacksonville, FL
    413
    Thanks!
    Awesome news... ;)
    Oct 2012
    Sacramento, CA
    864
    Awesome news... ;)
    I also didn't have a preview image setup and followed those steps and its working now
    [URL="http://www.komby.com"]http://www.komby.com[/URL]
    Facebook: [url]http://www.facebook.com/com.komby[/url]
    May 2012
    Vancouver, WA
    850
    Well, I installed onto a different machine, disabled the GDI, now it crashes on startup...
    Two things,
    Sheboygan, WI
    1,712
    I'm still having troubles with the preview. My 24 string pixel mega tree works fine, yet two strings of pixels that line a fence cause the preview to lock up. I cannot make a matrix using the smart objects - they don't work. Same with my pixel mini trees.
