Page 1 of 4 123 ... LastLast
Results 1 to 10 of 38
Thread: Getting the hang of Vix 3, but having tons of trouble
    Sheboygan, WI
    1,714
    Default Getting the hang of Vix 3, but having tons of trouble
    I am finally getting Vixen 3 figured out but am having tons of trouble.
    First, I cannot do anything with my pixel megatree. Any effect dropped onto the tree does nothing. I just get a gray box where I dropped the effect.
    If there are any other effect dropped on another element it also goes gray. When I attempt to play the sequence nothing happens on the preview. Also when I have these issues and I close out of Vixen the software does not close. The preview stays open and I have to give it the 3 finger salute.
    HELP!
    Attached Files Attached Files
    Oct 2012
    Sacramento, CA
    864
    Default Re: Getting the hang of Vix 3, but having tons of trouble
    HELP!
    I have had that issue. I think it is resolved in the upcoming release.(not sure when thats coming)
    [URL="http://www.komby.com"]http://www.komby.com[/URL]
    Facebook: [url]http://www.facebook.com/com.komby[/url]
    Jan 2010
    Jacksonville, FL
    413
    I will try to get an answer back to you this afternoon as to why this is occurring..
    In the meantime: What version of Vixen 3 are you using??
    HELP!
    Sheboygan, WI
    1,714
    I'm using 3.0.7
    Jan 2010
    Jacksonville, FL
    413
    go into your My Documents\Vixen 3\SystemData folder
    Make a backup of your SystemConfig.xml file... If this file is >3MB Zip it up to SystemConfig.ZIP
    and then Upload the file here: http://vixen.azurewebsites.net/
    It will then prompt you to download a new SystemConfig.xml file... save this over your old one.. (You do have a backup of it first right?) and see if your issue goes away...
    It should (did for me)
    This utility will fix this issue and the problem where users cannot patch their elements...
    Going forward in a future release, hopefully this will be a non-issue and we can integrate these fixes into the application itself... but for now.. Its what I can do for now to alleviate some of the angst...
    Sheboygan, WI
    1,714
    OK, I did as you suggested. It is running better but I am still having the same issue when I use multiple elements. can run more elements than before, so it is a step in the right direction. Using more than 4 causes the preview to lock up. I do not have any controllers connected so I do not know of the actual data output stops.
    Virginia Beach, VA
    1,333
    gizmohd,
    i have some of the same problems that TJ is having but when I tried to upload a file I get Zip File does not contain the systemconfig.xml file. When I open the Zip file I can see the file is there. The first error I was getting on upload is the Zip file does not contain the systemconfig.xml.xml file.
    Frustration meter increasing.
    More channels then I can use.
    More light bulbs then I care count.
    [url]http://www.vimeo.com/user1106747/videos[/url]
    Jan 2010
    Jacksonville, FL
    413
    Email me your file. Darren@gizmodevelopment.com
    Sent from my SGH-T889 using Tapatalk 2
    Sheboygan, WI
    1,714
    Any more on this?
    Jan 2010
    Jacksonville, FL
    413
    We are gearing up for a release in the next few days that should fix these issues. If you want to test it, take a look in http://www.vixenlights.com/builds for the 3.08.13 dev build. That is the latest release candidate. And let us know if it fixes your performance issues.
