Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: Color Organ for Vixen 2.x
    El Mirage Arizona
    40
    Default Re: Color Organ for Vixen 2.x
    "ADD IN ERROR - METHOD NOT FOUND: UINT64 VIXEN. CHANNEL GET-ID0;" this is the error I get when trying to do the color organ Im using latest version of vixen 2. Im also using a 64 bit windows 8 pro any help would be great!
    4,563
    The term latest version of Vixen 2 is actually misleading. The color organ supports Vixen 2.1 and Vixen 2.5. Are you using Vixen 2.5? The support for these two versions is provided by two different plugins. Based on the error, it looks like you are using the wrong version of the plugin for the version of Vixen you are using. Please check the versions and if they are correct, please send me a zipped copy of your sequence and details about which version of Vixen 2 you are using.
    El Mirage Arizona
    40
    When I get home from work I will do it. I'm trying Vixen 2.1.1.0 I already have Vixen 3 set up and running and a sequence but wanted to try the color organ! Thanks for the help!
    4,563
    Hi All
    I have made an update as part of a request by a user. Whats new: For a given color organ frequency set there are now 10 sets of channel selections that can be configured with independent on / off points . While this same thing could have been accomplished with multiple individual frequency band sets, this allows you to more closely relate the channel activity to frequency selection. FYI: This makes creating a VU meter effect super simple.
    Attached Files Attached Files
  5. Thanks dmcole thanked for this post
  6. #25
    Southern California
    1,036
    When I designed the Color Organ, I had not yet decided to use pixels and had almost no idea what it really ment to work with pixels. Now that I have some in my system, I can see that Vixen 2.1 and 2.5 are just not a good platform for managing pixels. I will use your suggestions when I port the Color Organ to Vixen 3 next spring.
    Martin
    Is this a feature in Vixen 3? I have been running Vixen 3.3u2 build#305
    Kevin
  7. #26
    4,563
    No Not yet
  8. #27
    Southern California
    1,036
    OK. Thanks. Is it something to look forward to?
    Kevin
  9. #28
    4,563
    Yes but not in 2017.
