Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Elexol EtherI/O Output Module?
    Jul 2008
    Brisbane, Australia
    901
    Default Re: Elexol EtherI/O Output Module?
    Thanks for that Tony. Don, are you able to confirm the latest dev build controller modules work for you?
    Michael
    May 2009
    43
    Everything worked great as of 3.08. I haven't tried 3.09 yet, I'll test it out this weekend and let you know.
    3
    Not working in 3.0.10. You cannot 'configure' the controller.
    After decompiling the .dll, it seems that the HasSetup override (new method?) needs to return 'true'
    I have a working version, if anyone is interested.
    Broken Arrow, Oklahoma
    631
    I will update the source and recommit to the main branch. Thanks.
    [SIGPIC][/SIGPIC]
    3
    I also use the Elexol EtherIO units. After installing the latest version (3.0.10) I discovered that it is not possible to configure/setup the module.
    I have downloaded and fixed the code, but am unable to submit the changes.
    * The modules now seem to require a 'true' result from a HasSetup override method.
    * a bug in the Setup form (Cancel button not working)
    * added some additional error trapping to prevent an unhandled exception if the Stop button is pressed when there is no communication with the EtherIO module.
    * limited the number UpdateState errors to a single Log entry, until communication is restored.
    I have tested the changes with my EtherIO modules and it is all working as expected.
    How can I post the changes back for someone to review and include in the main project?
    3
    Are there any elements that you would like some assistance with?
    I enjoy this type of project (interfacing with the real world) and would like to offer some time, if I can be of assistance.
    Peter
    631
    Quote Originally Posted by Pegan23 View Post
    If you want to send me a zip file with the corrected changes I can merge them with my code and then get them in the main branch.
    [SIGPIC][/SIGPIC]
    May 2009
    43
    Did this fix ever get introduced to the main branch? Any chance its going to work with 3.11 when it's released soon?
    Sent from my LG-LS970 using Tapatalk
    Jan 2014
    Whitianga, New Zealand
    91
    There is a Controller with the name Elexol Ethernet I/O 24 and also one called Elexol USB I/O 24 in Vixen 3.1. I don't have the hardware, so I cant test it.
    May 2009
    43
    Cool. I'll test them when the code is released. I have them both.
