Results 1 to 4 of 4
Thread: Adjustable Preview Error
    Orchard Park, New York
    281
    Default Adjustable Preview Error
    I started working on a sequence using Vixen 2.0.1.0. If I create the sequence as new and define the preview window at the same time then all is well. However if after I save the sequence and return to the plugin setup for the adjustable preview, select save (making a change on the preview is not important), then Vixen will abend immediately after I press play.
    The adjustable preview settins are 288 channels, 8 pixels, and a resolution of 1080 by 720. I painted in only 9 channels. I also downloaded a few version of Vixen to make sure the original was not corrupted.
    I've attached the error messages for your enjoyment :roll: , good luck old wise one
    Attached Files Attached Files
    281
    Default
    I checked the sequence file and when the sequence is first saved (and works) the preview size is defined as the following:
    <Height>700</Height>
    <Width>1050</Width>
    After the second save (and when it stops working) the size is:
    <Height>4900</Height>
    <Width>7350</Width>
    Setting the height and width back to the original values seems to correct the problem. Hope this helps.
    Bill
    Edit: Preview works fine if there is an attached image.
    Spokane, WA, USA
    684
    Default
    Thanks for doing some of the leg work on this.
    Apple Valley, MN
    3,195
    Default
    I get the same thing if I delete a graphic background and save the sequence.
    If I just delete the background and play the sequence, the preview window is huge. If I go back to configure the plug-in, the dimensions are now very large. Whether I change the values back to normal or not, Vixen fatally crashes. After I click quit, I get the Vixen is about to die message also.
