Results 21 to 30 of 41
Thread: Dan's Trolley Build
    428
    Default Re: Dan's Trolley Build
    Thanks, guys.
    2,192
    Quote Originally Posted by DanoNJ View Post
    Did I miss that you were planning a crossing sign?
    If I'd known, I'd have shared a circuit I built five years ago for the same thing.
    Yours is probably better than mine, anyway.
    \dmc
    ________________________
    428
    Quote Originally Posted by dmcole View Post
    \dmc
    No, you didn't miss anything. I tend to go off on tangents. This was a simple flip flop circuit.
    2,192
    My crossing light was my first real-world implementation of a Picaxe circuit. I couldn't make a 555 have the pauses I wanted.
    I have been meaning to sit down with a 555 for an afternoon and just damn well learn them.
    \dmc
    428
    After the cobwebs left today from the wedding I attended last night, I was able to get the power rails made. They are 1/8" x 1" alum flat bar. The tracks are made in 8' sections to help with set up and storage. To get the power to both ends, I had to join the sections, so what I needed to do is to put the joint below the rail so the pick ups would not skip.
  6. Likes JerryPlak liked this post
  7. #26
    428
    Work continues on this project. Here is the 'flip / flop' board for the crossing lights. Just stuck in a waterproof electrical box.
  8. #27
    428
    Big thanks to Dan Blick for help on the controler and Jack for sending me a voltage reg. Here is the set up.
  9. Likes JerryPlak liked this post
  10. #28
    428
    The controler uses a trigger to cycle thru the direction change. This is completed by a reed switch. One end is attached tot he body of the trolley, the button magnet is set into the track.
  11. Likes jklingert, JerryPlak liked this post
  12. #29
    428
  13. Likes jklingert liked this post
  14. #30
    Feb 2011
    Walker, IA
    213
    That thing's bound to be a hit.
