Page 1 of 11 123 ... LastLast
Results 1 to 10 of 109
Thread: Carousel Build
    428
    Default Carousel Build
    New for 2013, I started the build on a carousel. Unit will be just under 5' wide and about 5' high. I basing the build on plans I purchased from Winfield and will be completing some modifications.
    First step was to make the base which is simply some 2x6s. I made some wooden gears (a bit of a pain to cut out and make fit well). The main gear sits on a lazy susan.
    428
    Default Re: Carousel Build
    Of course I'm using a wiper motor for power running at 5vdc. These pictures show the motor housing and main gear on the base frame.
    428
    Floor sides cut.
    And the floor joists.
    428
    Center colum. The stringers have to be cut on an angle. The colum will be held in place by L's which have to be set into the strigers.
    Picture shows the inside of the colum before the skin is applied and the finished product.
    428
    Short video of the gears - test mode.
    http://www.youtube.com/watch?v=61iH2...bCnOCg&index=3
    428
    another short video of the floor on the base.
    http://www.youtube.com/watch?v=DQOoY...bCnOCg&index=2
    428
    Here is a picture of the base w/ gears. The center post adds some stability to the upper part of the unit. It does not get attached to anything, the colum slides over top.
    The other picture is the top. From each of those will be attached the roof rafters.
    428
    I made the decison to go with some 3/4" box steel for the roof suports to help with the possible sag / warp issue. What I did was cut to length and drilled and tapped one end. This end will be attached to the center support board. This makes up the bottom section of the roof structure.
    428
    On to the rafters. You'll get a better understand of the topper picture posted earlier now.
    And a dry fit of the parts.
    May 2011
    78
    sorry all the links to videos are bad you tube says video does not exist
    are you sure we checked every bulb?why is that one pixel staying on
    [url]www.thelightsonpurserroad.com[/url]
    2400 rgb channels for2014
