Results 1 to 10 of 13
Thread: Any EAGLE experts out there willing to look at this brd file?
    Columbus, OH
    4,302
    Default Any EAGLE experts out there willing to look at this brd file?
    This file worked in an older version of EAGLE, but not the latest.
    As a result OSHpark can't process it.
    OSH thinks there might be a problem with polygon overlay in the lower right; but not positive.
    I'm not versed in EAGLE and I figure someone here can fix this in 2 minutes.
    Thanks in Advance for any help!
    So.... here's the file in the attachments (its little, 28KB)
    Attached Files Attached Files
    10,283
    Default Re: Any EAGLE experts out there willing to look at this brd file?
    Well - - when I run DRC it calls out 69 errors - the majority are dimension errors but it doesn't like your pours (polygons) at the upper left corners - you may want to redraw those and increase the size of your board outline a hair all the way around. DRC is your friend! Check if OSHPark has a set of DRC rules (I think they did). Also I always had problem on the gerbers and straight board files. I found their CAM job (or just uploading my .brd files since they just run their CAM job on them...) didn't include a couple layers and all my parts had no names/values - - not good...
    I'm attaching the one I use to create Gerbers that I have used for OSH myself.
    [/SIZE]
    [/COLOR][/I]
    Tustin, CA
    2,143
    I'm not an expert but check all the locations where polygons change direction. Any overlap even by the smallest amount will fail. With version 5 and 6 the program will report an error during a check but maybe earlier versions did not. I had this happen when moving a polygon. DRC found it but I had to look very close to see the overlap.
    OSHPark does have a DRC file which the highly recommend you use.
    Mar 2010
    Leesburg Florida
    2,490
    Try this. The floods really need to be changed.
    Columbus, OH
    4,302
    Mac,
    Thanks for taking the time to fix the board. I owe you one.
    It uploaded to OSH without a hitch.
    Quote Originally Posted by Mactayl View Post
    Mar 2010
    Leesburg Florida
    2,490
    Mac,
    Your welcome,, I could clean it up a bit more if you want me to.
    Columbus, OH
    4,302
    No need. OSHpark likes it now and THAT is what I needed.
    Thanks again.
    420
    An Eagle presentation on one of the Friday night chats would be great!! <hint, hint>
    Jan 2011
    Ocean Springs MS
    1,004
    Quote Originally Posted by DanoNJ View Post
    That would be AWESOME...
    Columbus, OH
    4,302
    Okay.... I have another board with the same problem.
    Was fine with prior versions of EAGLE, but now won't process at OSHpark.
    Yes, I promise to start learning EAGLE, but I would certainly appreciate some help again.
    Here's the brd file.
