Results 1 to 10 of 20
Thread: 3D plastic Printing, Makerspaces - Cross over into Christmas.
    Middle Earth
    2,264
    Default 3D plastic Printing, Makerspaces - Cross over into Christmas.
    Hey folks,
    I've recently had need to create some "parts" to enable me to improve the cooling of a customised enclosure for a project. Essentially it was a tube with a flange. 3D printing is all the rage apparently and last year i bought a printer but had hardly had time to use it. So now i had a real problem, i put some time and effort into using it :-) Lucky the guys at my local makerspace, are gurus in this stuff, and they gave me a few pointers.
    I drew the "shape" using Adobe Inventor Fusion, which is free. It took about 60 minutes to print out this cooling 'tube'.
    Now i know many of you dont' have a 3d printer or would go out and buy one, but many many makerspaces exist around the planet now, and many of you could benefit from looking up your local one. They are often equipped with Laser Cutters, Mills, 3D printers and all sorts of other stuff that you proably won't have in the average home workshop. As well as having lots of 'know-how'. you might not find other christmas light fans, ( you might ).. You'll certainly find people who know how to solder if you dont' know how for example.
    Fees and costs for makerspaces are quite varibable depending on what you get.. Google "makerspace" you'll find 1000's of links and proably some contact details about something local.
    [B][FONT=Arial]stell[COLOR="#FF0000"]a[/COLOR][COLOR="#008000"]s[/COLOR][COLOR="#0000CD"]c[/COLOR]apes[/FONT][/B] - LED lighting solutions for the Prosumer, Commercial and Entertainment Industries.
    Doing pixels first since 2009 with [URL="http://www.youtube.com/watch?v=GAt6A98lXQw"]just another megatree.[/URL]
    Follow us on Facebook at [url]www.facebook.com/stellascapes[/url]
    web: [url]www.stellascapes.com[/url]
    Jan 2011
    Ocean Springs MS
    1,004
    Default Re: 3D plastic Printing, Makerspaces - Cross over into Christmas.
    Cool! How long did it take to make that part? What printer do you have?
    Middle Earth
    2,264
    Quote Originally Posted by Donny M. Carter View Post
    About 30 minutes to draw up, and 1hour and 5 minutes to print. NB i printed it at .34mm strata ( the slices ) which is quite thick. The machine will go to 0.1mm slices, which gives a much finer apperance, but also takes a lot longer ( this would have taken 5 hours ) to print and there woud'nt have been any gain made.
    I have a Makerbot Replicator
    Jan 2011
    Ocean Springs MS
    1,004
    That's a really nice machine! Not sure what I would make (probably a lot) but I would love to have one!
    Mar 2010
    Delaware, OH
    670
    Nice!!! What kind of machine do you have? I have been thinking about getting one myself but can't tell the difference between a good one and a bad one. Been wanting to do some "learnin" before shelling out the bucks.
    Jan 2011
    Ocean Springs MS
    1,004
    Quote Originally Posted by ebrady View Post
    See post #3!
    Mar 2010
    Delaware, OH
    670
    See post #3!
    Missed the last sentence, thanks!
    2,147
    I tried a Makerbot Cupcake a couple of years ago. It was fun to play with. 3D printers are great for low-volume or custom parts, prototyping, etc.
    It worked well for larger parts like chess pieces, but I found the Cupcake resolution wasn't quite good enough for small precision parts like sockets for PLC6 RGB LEDs. The electronics and print heads have gone through a couple of generations of improvements since then, so the newer ones are probably more accurate now (and of course the higher-end printers could do it). I think it would also work well for custom enclosures, although plastic containers are easy to come by from other sources.
    There are several web sites such as Thingiverse.com that have a lot of parts designed and uploaded by others, so that can be a real time-saver if you want to print something that somebody else already designed - just download the STL files, generate the GCODEs, and print your parts.
    I hope that PCBs get to this point eventually. (I've read that people are working on that, and looked briefly at some of the designs for printable resistors and capacitors, etc). It would be very cool to download a PCB file and print it, then solder parts onto it (for those that could not be printed directly onto it), connect it and start using it!
    There are lots of videos on YouTube about 3D printers. Here's one showing a Cupcake printing a part:
    http://www.youtube.com/watch?v=b7ROMuyyaOM
    EDIT: BTW, a heated platform is recommended for larger parts on this type of printer, to avoid warpage of the printed part as it cools
    don
    Last edited by djulien; 02-16-2013 at 10:09 PM. Reason: added video link, heated platform comment
    Click for display details >>
    2,147
    We might be getting closer to that goal - check the video in this article:
    It's not a Terminator, but scientists create liquid metal with 3D printer
    http://cwonline.computerworld.com/t/...7535/619968/0/
    don
    2,147
    getting even closer! check this out - interesting KickStarter project:
    http://www.youtube.com/watch?v=lVOFvywbfSc
    (I know it's an old thread, but future readers might find it interesting to follow the progression)
    don
