Results 1 to 10 of 21
Thread: preview hassels
    Feb 2012
    Kadina,South Australia,Australia
    484
    Default preview hassels
    HI guys , am having real problems drawing on preview screen. Lines wont start where i want them, seems to be random points where i click on the page but not where i wish to start then stop. Any one have ideas, videos are all of the old methods using incan's/ I am using pix and have pixel plane and segmenst on the grid (left pane), What am i doing wrong please, The Umarg explains it well but it dont work for me. I assume i'm doing something wrong.
    Cheers and THanks for the help
    Boof63
    5,687
    Default Re: preview hassels
    you need to give 1 left click to select your starting point .
    http://www.youtube.com/watch?v=F6cTYgqDN3M this will clear things up .
    Dec 2008
    Rancho Cordova, California
    307
    Default
    Hay Boof, were you able to get it working? I ask because early on I was having the same sort of troubles and it ended up being caused by the sequence of actions I took. It's was back in version 11(x) and it was during use of the old preview. What version are you working with?
    "Some let things happen, others make things happen. Which are you?"
    [B]Powered by[/B][SIGPIC][/SIGPIC] [B]since 2012![/B]
    Feb 2012
    484
    Using 12U version and understand about Lclicl . but it dont want to work, where i wish to start at a certain point. Rather Frustrating. will check video later thanks, heading out for RL sports meeting,
    cheers Boof63
    Key West, FL
    3,615
    Quote Originally Posted by Boof63 View Post
    Boof63
    When you open Preview - either Edit or Normal - I create a "DebugGraphicsAdapter.txt file in the Library folder.
    Send it to me.
    It appears someone else had a Preview issue was because his Graphics Card did not have enough memory.
    Joe
    Feb 2012
    484
    Hi joe here is debug file, hi i seem to be able to draw lines now and a sqaure came up for a mega tree, but thats all. If i click "save" it does but nothing else happens
    cheers Boof63.
    Attached Files Attached Files
    5,687
    Are you running Win Xp with directx 8 ?
    you could upgrade that to ver.9
    http://pcsupport.about.com/od/fixthe...directx9xp.htm
    Feb 2012
    484
    running win7 and ver9c . 4gig ram and 1gif video card
    Key West, FL
    3,615
    cheers Boof63.
    The debug file shows capabilities like mine.
    I am going to add some more debug data in a future release - like Graphic Board type, etc to see what happens.
    Try a smaller display as a test --- 800 x 600. This would reduce the amount of video card memory required --- see if that helps.
    Let me know.
    Joe
    Key West, FL
    3,615
    cheers Boof63.
    I just released 12Y
    Did a small change to DirectX setup.
    Also added some more debugging info.
    Try 12Y --- let me know how it goes and send the updated debug file.
    Thanks.
    Joe
