How to cover your yard in fake snow that looks good.
I found a good low cost material to make your yard look like it's covered with snow.
The material comes from the Upholstery Supply stores. Its Polyester LowMelt Fiber 3/4 Oz wrap, sometimes called Kodel Rolls, use as a cover on upholstery. It comes in 30", 54" and 72" wide 30 yard rolls. In my area the cost is around $30 for 30", $54 for 54" and yes you guessed it $72 for 72".
Basically you mark where all of your props will be located, run all of the wires, lay down the fake snow, you stake it down with cut white coat hangers bent into a "U", covering all of the wires and then connect all of the props. That way they props are on top of the snow. When you place props or stake it down the material looks like the snow has melted around them. It's a cool look.
Don't worry about water, in fact water makes this look even better. The polyester holds some of the water which refracts the light making it look like fresh fallen snow. Again giving it a cool look. So let your sprinklers do their job.
Don't worry about the grass as enough light will get through. People in my area use this and the grass is in good shape when it's all removed.
This is a yearly expense since it's not worth trying to save it for the next season, just toss it in the recycle bin.
Here are some pictures from some displays near by. I think they look great even though they didn't hid the wires as well as they could have.
Re: How to cover your yard in fake snow that looks good.
I actually took a few pics as I was removing my snow to show how the grass looked. First year I've done this so I was pleasantly surprised. I was able to find 120" rolls in the garment district in LA for about $80. And IIRC, they were 45 yards? I found this useful when searching for batting: http://www.villagequiltworks.com/ima...ttingChart.pdf
I looked for the thickest stuff I could find. There was cheaper stuff, but it was thinner. I can't remember the exact place but it was someehere in this vicinity: https://maps.google.com/maps?q=garme...22.67,,3,11.27
There were a ton of places that carried similar stuff. Walk around and find what works for you.
A friend of mine cobbled together an all-in-one machine that has an air compressor head and a power washer head, both driven by a trio of V-belts from an 18-20 HP horizontal engine he got off some kind of dead yard machine.
Pagoda Picture.jpgDepending on the conditions you can get a couple years out of it. The lower positions on this pagoda get dirty faster so they get moved to the roof after the first year. After 3 years it is worthless though.
It does give a neat effect when lights are under it also.
