Thread: What output plugin to use for homemade controller?
    3
    Default What output plugin to use for homemade controller?
    Built a basic 8 channel SSR with a parallel port printer cable , installed vixen and creating a profile and sequence, my first time so take it easy on me. When picking a (output plug in) I dont know what to choose that will run my homemade controller. So close, help me over this hump please!
    9,236
    Default Re: What output plugin to use for homemade controller?
    Parallel port plugin.
    http://digwdf.com/store/
    Nov 2009
    South Jersey
    2,029
    I believe you choose the basic parallel plugin
    3
    Thanks for the response, but the list of output plugins does not have basic parallel on it.
    9,236
    Go to vixenlights.com and download the other plugins
    3
    Ok, I have the plugin I need, thank you. Now my next problem is I am using a parallel adapter express card for my parallel port, which I hope will work!! But for the life of me I can not figure out what port to use on my plugins?
    9,236
    What port does it show up as to the computer? Try that first. It may turn out that you'll have to change the hardware address to match that of your card, but try it first.
    Jun 2007
    Poway, California
    94
    Don't know if you ever got this to work w. your homebrew controller, but when using a plug-in parallel card, I had to use the "simple 595 w. pulse width" to put two pulses per vixen output. When using the m/b based parallel port, the "simple 595" worked fine.
    Nov 2010
    Placerville, CA
    2,199
    lpt0 is usually at mmio address 3BC (also known as the monochrome display card parallel port)
    lpt1 is usually at 378
    lpt2 is usually at 278
    That is the way IBM defined them
    [I][SIZE=2]"Beam me up Scotty, there are only limited pockets of intelligent life on this planet!!"[/SIZE][/I]
