Results 1 to 7 of 7
Thread: Deleting Vixen 2.1
    Silsbee, Tx
    1,096
    Default Deleting Vixen 2.1
    I upgraded to Vixen 2.5.0.8 from 2.1.1.0.
    I just about completed a sequence in 2.5.
    Can I go ahead and delete vixen 2.1.1.0 folder contents now without causing problems in 2.5?
    Xenia, Ohio
    1,354
    Default Re: Deleting Vixen 2.1
    Some people find 2.5.0.8 a bit buggy depending on your setup. Many run it without problems. Either way I would not delete your 2.1 folder unless space is a real problem. Deleting should not cause any problem with your 2.5 install.
    Another consideration is that there are more sequences available for 2.1 from which you can borrow. See http://www.landolights.com/main/comp...ory/Itemid,54/
    [SIGPIC][/SIGPIC]
    [/COLOR]
    Dec 2008
    3,923
    Quote Originally Posted by Xenia View Post
    Agree with this. Unless you have a compelling reason to go to 2.5 (Dimming Curves?) then I would stick with 2.1 for the reasons Randy outlined.
    Just finished my 4th season and I have never upgraded. Still running 2.1x
    Silsbee, Tx
    1,096
    Ok, well I have been having an issue with 2.5.0.8 with it hanging up. I posted in another thread I searched out on it. (General, Vixen Pause Problem)
    Silsbee, Tx
    1,096
    will I be able to move the sequence from 2.5.0.8 over to 2.1?
    Dec 2008
    3,923
    Quote Originally Posted by 11Bravo View Post
    Yes, there was a downgrade utility that KC created. Should be wherever you downloaded 2.5 from.
    Silsbee, Tx
    1,096
    I'm pretty sure I already ran the downgrade utility after I loaded 2.5. I probably didn't know what I was doing when I did the downgrade. Wasn't that the .exe
    file KC said to delete once it did it's thing?
    I opened up Vixen 2.1. Clicked on open sequence, and found the sequence file that I was working on in 2.5 and opened it. It was all there except the preview had the house picture in the back ground. I removed the picture and ran the sequence. All went well.
