Results 1 to 10 of 13
Thread: Tree Frame
    Jan 2013
    Utah
    8
    Default Tree Frame
    I have found a source for Small tree frames... I sent my specs to a company and they have said they can do it I have to order 200 of them to get them built and shipped.
    If anyone is interested in purchasing some just let me know. As soon as I have enough orders I will order them
    They are $10.00 each
    Attached is a couple of pictures of them.
    Mike Downey
    michaels.downey@gmail.com
    Jan 2013
    Utah
    8
    Default Re: Tree Frame
    They have 2 inch legs to help secure them in the ground... They have nine rings total for two reasons 1. to help keep a uniform shape 2. to allow for lights to be wrapped without so many zipties.
    Nov 2012
    Edmonton, Alberta
    69
    looks good, how tall are they? looking at the pic i'm guess 3 1/2 feet and a 12" base.
    Jan 2013
    Utah
    8
    They are 42 inches tall with a 15 inch base. I made some from Tomato Cages about the same size last year and decided to see if I could get better ones. I did a lot of research so I could keep my cost down. The only problem I have is that I have to order that many!
    Nov 2012
    Oklahoma City
    246
    so you buying 100 of them? MS
    Eagan, Mn.
    4,075
    note, lots of rings will help it hold its shape if you wrap them top to bottom. Most people wrap them around which would need more uprights to hold shape. I see you have 4, that's better than the three they come with but most people put 2 together making 6 uprights. It's your project and you do what you want, I just wanted to make you aware in case you didn't notice or think about this.
    Brian
    Tustin, CA
    2,143
    They look really nice.
    Push came to shove it would be easy to tie wrap 4 more rods if you we're going to wrap around.
    These would be great for mini pixel trees although the bottom loop may need to be a heavier gauge wire. I was thinking 16 strands which with 4" pixel spacing gives 10 pixels which is a perfice fit for 42". Question is the size of the top ring. I thing 2.5" is perfect as it give a top spacing of .5" and the bottom of about 3".
    Could the top and bottom rings be made with a circumference of 8" and 48"? That would be perfect for 12, 16 or 24 strans on 4, 3 and 2" spacing.
    I think 2" is a little short for the legs and maybe 4" would be a bit better.
    Lastly, have you thought about how to attach a star to the top?
    Jan 2013
    Utah
    8
    I thing 2" is a little short for the legs and maybe 4" would be a bit better.
    48" Ring on the bottom? I am trying to picture all of of your thoughts here.
    Mike
    Jan 2013
    Utah
    8
    Brian
    Six would be better... Let me see what would happen with that addition
    Jan 2013
    Utah
    8
    What size would be the best for attaching a star on top... I am open to all suggestions
    Mike
