Results 1 to 9 of 9
Thread: 12v vs 5v LEDs
    Lake Forest, CA
    9
    Default 12v vs 5v LEDs
    Just trying to get an understanding of why one would pick 12v over 5v or vice-versa.
    Thanks in advance!
    -Jerry
    6,219
    Default Re: 12v vs 5v LEDs
    It depends on the element in question as to wether 12v or 5v is the solution .
    Most , if not all RGB strip is 12v . Now if you get into pixel strip or strings there are many variants of 12v and 5v , for pixel strip the actual fcb is designed differently for 12v than 5v .
    I have a fair bit of both 12v and 5v elements and for my needs I prefer 5v over 12v .
    unfortunatly I like rgb strip and it is 12v . rgb and pixel strings are abundant in 5v and 12v .
    Also it is possible that 12v can power an longer strip or string of pixels than 5v without color degradation .
    Jul 2008
    3,275
    There is a lot of confusion about this. It is all about compromise.
    When you have 12V and your LEDs have a forward voltage of say 3V...you have to drop the supply by 9V.
    NEGATIVE: This is WASTED POWER given off as heat to the resistors.
    POSITIVE: It is easier to transmit current over longer distances (this is the color degradation angus mentions above).
    When you have 5V and your LEDs have a foward voltage of 3v...you have to drop the supply by only 2V.
    POSITIVE: Less power waste
    NEGATIVE: Large amounts of current at 5V are very susceptible to voltage drop. This typically requires multiple power injection points along a string.
    WLC Ventures is now [URL="http://radiant-holidays.com"]Radiant Holidays![/URL]
    2,147
    Quote Originally Posted by g2ktcf View Post
    Doesn't this depend on how the LEDs are connected? For example, in the LED strip that has LEDs in groups of 3 in series, it only needs to drop ~ 3V. You end up using the same 60 mA for 3 LEDs instead of 1, so there is less current needed at 12V in this case.
    don
    Click for display details >>
    Jul 2008
    3,275
    don
    That is always a possibility...it is a compromise so knowing the schematic of what you are buying is important.
    Las Vegas, Nevada, U.S.
    2,156
    I have been seeing more and more 24v led strips as well. I think I will be sticking with 12v. I have already heard what happens if you make a mistake and run 5volt stuff on 12v by accedent.
    Projects:
    Videos
    Albuquerque, NM, US of A.
    633
    Let me guess, the magic smoke gets out?
    Jun 2009
    Ottawa, Ontario, Canada
    2,846
    Standard Disclaimers apply:
    2,156
    Yep refering to that post
    Projects:
    Videos
