Thread: European voltage 220v?
    Serbia
    30
    Default European voltage 220v?
    whether firegod for the European voltage 220v 50Hz or 110v only american 60Hz?
    Apr 2012
    3
    Default Re: European voltage 220v?
    Hello Vlad,
    With the right hex code, work nice also with 220v/50Hz power networks. You need also to choose a "sinking" version of SSR. Please read all information about Firegod and SSR. You can find all in the Viki, http://doityourselfchristmas.com/wik...itle=Main_Page
    Good luck,
    Cata
    Jul 2008
    Pearland, Tx (sometimes) and anywhere on the globe the rest of the time
    3,274
    vladakru,
    Just so you know, I talked to Firegod a month or so ago. I don't think you will see any more of his boards around unless you get one from a member. His bill of materials is for 110VAC only but modifications could be made. I have a 220VAC version of the Renard 64XC and the SSRez in my online store at www.wlcventures.com
    Cheers
    Chris
    WLC Ventures is now [URL="http://radiant-holidays.com"]Radiant Holidays![/URL]
    Serbia
    30
    I want to know whether the difference between 110Vac and 240Vac transformer itself or in something else?
    Dec 2015
    UK
    158
    Quote Originally Posted by vladakru View Post
    110v is the voltage that comes out of the sockets in America, and 240v comes out in Europe. Transformers convert this voltage down to a lower voltage. Serbia uses 220vac.
    AC means alternating current, the polarity is switching 50 times a second, 60 times in 110v countries.
    You will need to use 220v transformers and appliances, but many switch mode power supplies and appliances will work on both voltages.
