Results 1 to 5 of 5
Thread: xLights Nutcracker effects with LOR export
    Littleton, Colorado
    2,592
    Default xLights Nutcracker effects with LOR export
    The latest release of xLights has added the ability to create a LOR lms or a Vixen vix file.
    http://dl.dropbox.co...setup-2012e.exe
    I think you could get scrolling text or a butterfly created in < 60 seconds for either one. Creating a lms file takes about 4-5 minutes if you have a large channel count. I had a 4 minute song, 100ms frame timing and 12000 channels, this is probably why it took 4-5 minutes to create the lms.
    It took a little over 6 minutes to load the lms file. The lms file was 1.26gbytes.
    I made a video of how to install and use xlights, version 2012e
    http://dl.dropbox.com/u/50766638/xli...etup-2012e.exe
    My current Nutcracker is php and mysql. My code is a few megabytes in size. If you want a local install you need to download wamp or xampp. These are ~ 350mbytes. xlights is a 5byte file. it works on windows xp, 7 and 8
    xLights is in C++ .
    matt does have horizontal matrix., megatree, vert matrix and single strands targets.
    he has all effects except for animated gif, twinkle, tree and countdown
    thanks
    sean
    Sean
    Littleton, CO
    Latest releases [url]http://nutcracker123.com/nutcracker/releases[/url]
    xLights/Nutcracker Forum [url]http://nutcracker123.com/forum/index.php[/url]
    Facebook [url]https://www.facebook.com/groups/628061113896314[/url]
    [IMG]http://nutcracker123.com/nutcracker/images/ZZ_SEAN5.gif[/IMG]
    Eagan, Mn.
    4,073
    Default
    Sean is the flat garland in xlights considered a bug?
    Brian
    Sent from my SCH-I500 using Tapatalk 2
    Dec 2008
    3,923
    Default Re: xLights Nutcracker effects with LOR export
    Sean,
    Have you and Matt talked about an architecture that would allow for upgrading and adding effects without him redeveloping?
    Can't wait to start playing. It would be great if your effects engine could be integrated into all of the new sequencing tools like HLS and Vixen 3.
    Thanks for all of your work.
    Jul 2012
    Novi, MI
    396
    Cannot wait to start using this.
    Littleton, Colorado
    2,592
    Quote Originally Posted by kychristmas View Post
    Sean,
    Matt and I and others might get a conference call sometime in january to discuss the future. Currently xLights does not have the ability to share the effects you create with other users. There is no central database, therefore no gallery. There is no animated gifs so you cant post your cool effects for people to see. Single strands are limited to strings of the same pixel count, there is no ability to define odd segments (like when i wrapped my Halloween spider).
    But , yes, one architectural design would be to allow an effect to be a) written by someone else, b) shared among Vixen, HLS, LOR and LSP developers.
    watch this space, it will be a fun ride in 2013.
    Sean
    Littleton, CO
