Thread: This may help you who are using hls with com port issues ( this is not for dmx )
    6,219
    Default This may help you who are using hls with com port issues ( this is not for dmx )
    I built one of theses adapters on the cheap and you can get the parts at your local electronics store .
    All credit goes to Brian-Budude and Dave -Dirknerkle and the wiki for getting me started and up and running with my first renard board .
    This adapter worked perfectly with hls and my renard ss and 48lsd boards .
    Hope this helps you get your shows working for this year .
    Cheers
    http://doityourselfchristmas.com/for...a-computer-usb
    Nov 2010
    Charlotte NC
    646
    Default Re: This may help you who are using hls with com port issues ( this is not for dmx )
    I don't want to the bearer of bad news, but that is how I made my (2) adapters and I am having com port issues. I think it may depend on the "USB to RS232 DB9 Serial Adapter Cable" that you buy.
    I bought from Monoprice ~$5.95ea and they kept failing (ie the lights froze, while HLS kept playing and sending data).
    I also bought expensive ones from Staples ~$37.00ea, same result.
    Discussed this with Joe and noted neither had a FTDI chipset (That may or may not solve the problem).
    Further troubleshooting revealed that the on board 9 pin Serial PCI card worked fine. Right now looking for a second 9-pin PCI to try as I need two com ports to run my show.
    3rd Year - 640 channels - 18,706 lights - 1 Lost Mind
    FACEBOOK: Fallatt's Charlotte Christmas
    Las Vegas, Nevada, U.S.
    2,156
    You may also have a unused com port internaly that just needs something attached. Like how frount pannle usb ports atttach. Assuming a desktop.
    I have a few difrent brands of serial cables if you or joe want more test resualts. Just pm me + and sequence you want me to test. Incuding ftdi
    Projects:
    Videos
