Page 3 of 149 FirstFirst 123451353103 ... LastLast
Results 21 to 30 of 1488
Thread: Home Brew Lighting System - Arduino Mega - SainSmart 16 Channel Relay Board
    Nov 2012
    280
    Default Re: Home Brew Lighting System - Arduino Mega - SainSmart 16 Channel Relay Board
    HA! Check this out I just found my Christmas lights project videos featured on the SainSmart site. They sell the relay board I used. http://www.sainsmart.com/16-channel-...ttl-logic.html
    Nov 2012
    280
    Here is the datasheet on the relays on the 8 channel SSR board, but I'm not sure how to read the zero-cross part:
    http://datasheet.octopart.com/G3MB-2...eet-111010.pdf
    My boards have the G3MB-202P-5VDC relays. Does the Yes in the Zero-cross Function column of the table indicate this is Zero-Cross or is random cross, I assume zero which means these won't do dimming any better than the mechanical relays on the 16 channel boards.
    If that is true I wonder if the relays can be replaced with the other type G3MB-202PL-DC5.
    Nov 2012
    280
    hmm apparently the G3MB series has been EOL'd and replaced with G3MC series. The 202P and 202PL look foot print compatible. It may be possible to swap these out.
    Jan 2013
    7
    Quote Originally Posted by zparticle View Post
    I saw that and thought it an endorsement of the original relay, but upon further investigation, found your issue with dimming. BTW, Those vids were my original inspiration, and the source code the original base I started from.
    I read it the same way you do. 202P is a zero-cross, and the 202PL is a random cross. I am just too stupid to understand exactly what that means. I do, however, realize that we need random cross SSRs.
    Man I would hate to have to dust off my soldering skills on something that is carrying 120v.
    Nov 2012
    280
    here is the best explanation of of zero-crossing/random-crossing I've found yet.
    http://www.crydom.com/en/Tech/Newsle...ng%20types.pdf
    Looking at the boards replacing those relays should be a snap.
    Nov 2012
    280
    Well I took the plunge. I just ordered 16 of the G3MC-202PL-DC5 from Mouser at $5 a piece. I'm going to try to replace the G3MB-202P-DC5 relays with the random-cross relays and see what happens.
    Nov 2012
    280
    BTW the latest code can now be found here: http://code.google.com/p/arduino-chr...tem-for-vixen/
    Oct 2009
    766
    zParticle -
    I have the SainSaint SSR board and yes it uses the G3MB 202P Omron SSR. Hope the switch works for you.
    Morrisburg, On, Canada
    2,541
    As you may have discovered, the zero cross function SSR uses the AC zero-crossing points to turn the relay ON. Since this turn-on point is always the same (at zero), it can't be used for phase control dimming. It is possible to use dimming by "burst mode", but that may cause some flickering due to the lower PWM frequency. I also have not seen anyone here use that method, even though it is technically feaseable, as explained in the crydom pdf from post #25.
    The random SSR can be turned on in any part of the AC cycle. However, to make AC dimming work your Arduino software must know where the AC cycle starts. If you don't give the Arduino the zero crossing point then your random SSR is not synchronized to the AC line and thus will dim poorly.
    Does your Arduino board have a zero crossing detetion input? Your firmware needs to use this signal for dimming.
    Nov 2012
    280
    Ah, I wondered about that. The Arduino doesn't have the zc detection, however I suppose I could make a little circuit for that. Thanks for the info. I'll do it in stages, see what it looks like without the ZCD first and then go from there.
