Results 1 to 7 of 7
Thread: Eddie Effect for HLS
    Sep 2012
    20
    Default Eddie Effect for HLS
    Attached is a file called EddieEffect.xls. It is inspired by Fast Eddy of Auschristmaslighting.com. If you use HLS and have Excel it is a fast way to make effect files that move colors horizontally across your entire light display. This allows for real quick setup of 16 universes and you can get the effects made in a matter of seconds.
    Attached Files Attached Files
    Jul 2012
    132
    Default Re: Eddie Effect for HLS
    Thanks, will take a look at it
    [SIGPIC][/SIGPIC]
    Sep 2012
    20
    I just realized that Excel reverses color and gives bgr values instead of rgb values. Attached is a corrected file.
    Sep 2012
    20
    Here is a video that shows some of the effects you can make from Eddie Effects for HLS. It is also a tutorial on how to use EE and how to use the results in HLS.
    http://youtu.be/vOY8-qn3otg
    5,697
    Thank you BWalter for making this tool available and doing this tutorial .
    You make it look easy sequencing custom effects what a great addition to hls .
    Cheers
    Richard
    Nov 2010
    Livermore, CA
    2,128
    Thank you sir, looks great. Getting an error when trying this.
    The debug highlights the timeline line.
    I've just got what I consider 4 strings, roof1 , pillar 1 pillar 2 and flood1 1-10
    fileout = Fname + fileout + ".hls"
    fileout = Replace(fileout, " ", "")
    My_filenumber = FreeFile
    Open fileout For Output As #My_filenumber
    For p = 0 To UBound(outrows)
    timeline = ""
    For r = 1 To 10
    rr = outrows(p) - ((p + 1) * 100) + r - 1
    If rr > 10 Then
    rr = rr - 10
    End If
    timeline = timeline + FiniStrs(rr)
    Next r
    If rr < 0 Then
    MsgBox ("1")
    Else
    Print #My_filenumber, timeline
    End If
    Next p
    Close #My_filenumber
    Wondering What I could be doing wrong?
    thanks
    Tory
    Sep 2012
    20
    The most likely issue the setup of the strings on the layout tab. Perhaps you could do a screen print of that screen and post it here and will look it over.
