Page 2 of 19 FirstFirst 123412 ... LastLast
Results 11 to 20 of 182
Thread: 6 Port E1.31 to DMX Bridge Pre-Sale
    Sep 2009
    Omaha, Ne
    3,145
    Default Re: 6 Port E1.31 to DMX Bridge Pre-Sale
    Quote Originally Posted by Slite View Post
    Sweet!
    A placed an order for a REn 48 LSD as well, can you please put that in the same package as the DMX Bridge, I posted the order number for the Bridge in the comment on the latest order.
    Saw that, You will get an invoice after I am done sorting, I am not sure if both will fit in a small box yet.
    Mölnbo, Sweden
    325
    Quote Originally Posted by dlovely View Post
    If not, send them separatly, or a bigger box, which ever is cheaper
    Blinky Blinky Lights! Suffering from C.L.A.P. (and not afraid to admit it)
    [url]http://www.blinkylights.se[/url]
    Jun 2008
    Pompton Plains, NJ
    273
    Is there a manual for this? And what IC is supposed to go on IC9? I see it doesn't come with the kit but would like to add it.
    Sep 2009
    Omaha, Ne
    3,145
    Quote Originally Posted by Ponddude View Post
    No manual yet, I hope to get a Wiki page made for it but with the holidays and family events I have not had time to start it yet. The IC9 is for a future support of a MAC Address IC. Part number for it is 24AA025E48-I/SN. It was not included as the code for it is not done yet, I hope to support this in a future update.
    Jun 2008
    Pompton Plains, NJ
    273
    Ok thanks...that is what I was looking for.
    Works great so far
    Jul 2008
    Western N.C.
    546
    Got mine today. Thanks a million!
    ***20 Characters!***
    Sep 2009
    Omaha, Ne
    3,145
    I just received an email from someone noting that they are using a picture of the board to install the components. I just wanted to point out that the prototype PCB (The purple one) the WizNet points to the edge of the board, where in the production PCB (The black ones) the WizNet points to the Propeller IC. This was a change made on feedback after posting the prototype pictures.
    Sep 2009
    Omaha, Ne
    3,145
    Here is a picture of the production PCB. I didn't have the parts in yet so I had to use what I had laying around at the time and didn't have extra RJ45s to use at the time so that's why they are missing along with the DC-DC converter.
    Lehigh Acres, FL
    21
    Thanks for the update Jeff
    2012 First Year
    4 PC16 LOR
    2 1602W LOR
    4 DIYLED bridges 6 ports
    5 E682
    4 E6804
    5 27 channel RGB boards ( 9 Groups )
    25 3 channel RGB boards
    4900 Channels Of DMX
    All Running on E1.31
    About 95,000 Lights at this point
    Toronto, Ontario
    223
    Can you give a real quick rundown of how to connect it up the first time? I got mine built and powered up. Just not sure of the initial IP setting so I can get into the configuration page,
    Edit: Seems the setup is very much like RPMs bridge. Still having a problem though. The units config can't be reached unless I do a mode-reset, and only if I try to reset it to DHCP.
    If I set it to static, I can't reach it at either the configured IP or the defaults
    If I set it to DHCP, the DHCP fails but I can access the config at 169.254.74.73. However, after changing the protocols or any settings, after a save and reboot the unit stops responding again.
    I have the following as the default info when it reboots after trying to for DHCP (the only way I can reach it)
    Code:
    Current Network Mode is: FORCED DHCP FAILED
     IP Address: 169.254.074.073   Subnet Mask: 255.255.000.000
        Gateway: 000.000.000.000    DNS Server: 000.000.000.000
    DHCP Server: 000.000.000.000MAC Address: 4A:49:4D:CD:5A:CD DHCP  Lease Time Remaining: 0000:00:00
         Firmware Rev: 2.00
    E1.31 Packet Statistics:  Socket S1    Socket S2    Socket S3    Socket S4    Socket S5    Socket S6
     Universe Number                1            2            3            4            5            6
     Packets Received               0            0            0            0            0            0
     DMX Channel Count            512          512          512          512          512          512
    Global Configuration:
    Static Network Information:
    IP Address: 192.168.005.206   Subnet Mask: 255.255.255.000
       Gateway: 192.168.005.001    DNS Server: 192.168.005.001
    Default IP Mode: STATIC  Web Server Mode: 3  Bootup Initial Mode: 0
    Thanks for the help
