Results 1 to 10 of 16
Thread: E682 and lor s3
    Mar 2010
    westmont, nj usa
    73
    Default E682 and lor s3
    Don't know if this should be in the lor lagoon or no. Please move if necessary.
    I am looking to set up my e682 to lor s3. The e682 is connected to a switch and the computer is on the same. The e682 web server is accessible and I can run all the tests just fine. But lor won't send sequence commands to the controller or well the pixel strips won't light. The green light on the mag jack blinks but the green status light on the board is off or comes on dim sometimes.
    I am using 1804 pixels by the way.
    5,436
    Default Re: E682 and lor s3
    You will need to share a lot more info .
    how are you connecting to the 682 through a router or directly from nic to switch ?
    is lor setup and configured for e1.31 and correct universe etc?
    could you post a pic of the 682 config ?
    10,283
    For LOR E1.31 don't you have to keep a utility open at all times - I don't recall the name of it but I seem to recall reading a post about it...
    Brian
    Halloween in San Jose! - FB
    Jan 2011
    Ocean Springs MS
    1,004
    Yes, LORCommListener!
    Mar 2010
    westmont, nj usa
    73
    Default
    The e682 is connected to a switch and the computer is on the same switch. Then the switch runs to my router then to my modem.
    The commonlistner is working too. All the universes come up and are recognized. I have 4 universes going to my lynx etherdogle. Then 5-10 are going to the e682.
    10,283
    Please post a screen capture of your E682 configuration screen. Make sure the tester is shut off - 'TE 0' then 'SA 0'.
    Brian
    5,436
    as brian said ,
    in 682 command line
    Test 0
    save 0
    quit 10 to free web config
    Nov 2008
    Lexington, NC
    2,165
    as brian said ,
    in 682 command line
    Test 0
    save 0
    On the E682, you don't need to kill the web config, since there's a dedicated processor handling that now. So the last line 'quit 10' isn't needed.
    Can you send any data to the E682 with something besides LOR S3? SACNview is a good tool to send data via E1.31 to check configuration of E682. But posting a screen shot of your config will help us help you.
    Mark
    1,148
    I made a simple checklist that might cover something you may have missed. It doesn't cover any settings for the E682 since it's on the LOR help Forum. But there are a couple things in there that might be roadblocks to getting the lights to blinky/flashy.
    Jeff
    Mar 2010
    westmont, nj usa
    73
    Interesting. The help page worked. Didn't know that the e682 ran on multicast. I specified the ip from the beginning. but got it to work now. Thanks for the help.
