Results 1 to 10 of 15
Thread: LOR or D-Light
  1. Default LOR or D-Light
    I am looking for input here: which is better; Light-o-rama or D-light? Please give me some feedback about the controller itself and the software. I need to know which one is better to use and if LOR is really worth over $200 more. I am looking between 16-32 channels. And sorry if this is the wrong category, I'm new!
    City of Lenoir, TN
    340
    Default
    Don't know too much about either, but you can learn to build your own here on this forum and save a ton of money in the process while getting a ton more channels. This is pretty much a do it yourself forum for Christmas lights controllers.
    Ahwatukee (Phoenix), AZ
    1,994
    Default
    Thats OK! We do have a few members here who use both! and hopefully one of them will pipe in and give you some good information. (Jeff.Mill and crazylightlady are two excellent sources of information)
  4. Default
    I am not looking to build one because i am no good with electronics at ALL. I have seen Computerchristmas.com and that stuff is just why over my head. Buying is really my only option right now and I would like to get a head start so I can sequence more songs before December!
    Lithgow, NSW, Down Under
    885
    Default
    I'm not putting down LOR or D-Light, but try buying a $20 soldering iron, some stripboard & practicing some soldering. It's not hard, and the pleasure you get is really worth it.
    It all comes down to practice - get the heat on, solder on, melt & heat away in as short a time as possible so you dont damage the parts or board. I look at the soldering I did 25 years ago & shudder, BUT the gear is still working (40 watt amp, still running in the shed almost daily).
    Heck, buy a few kits & practice there too. Even if you go LOR or D-Light this year, aim to become reasonable at soldering by next year & start making your own stuff then
    http://www.lithgowlights.com/
    Winder, GA
    37
    Default
    You'll find a lot more users of retail controllers at the PlanetChristmas.com forums. Most of the people here are diyers, and build their own controllers.
    PC has a separate forum for each retail controller; Animated Lighting, LOR, and DLight.
    Groveland Florida, USA
    65
    Default
    To get you started and maybe more interested ;) you could download Vixen sequencing software for free and get started sequencing right now for zero dollars.
    Code:
    Powered by
    ____   ____ _______  _____________  _______
    \   \ /   /|   \   \/  /\_   _____\ \      \
     \   V   / |   |\     /  |   ___\_  /   |   \
       \___/   |___/___/\  \/_______  /\____|__  /
                         \_/        \/         \/
    Midwest USA
    273
    Default
    Here we'll try and push you in the DIY direction, after all we are DoItYourselfChristmas! I had very little electronics experience when I started. There are tons of people here that can help take the confusion out of it - it's not really that complicated once you get the hang of it!
    If you are looking for something similar to LOR or d-Light I would suggest looking into the Renard16 (xmus16), Renard24, or Lynx.
    If you need help we are here to help you through every step of the process. If you still decide that you want to buy, I would suggest the planetchristmas.com forums as a great source of information.
    Good Luck!
    -Matt
    WI
    2,526
    Default
    While these posts of encouragement are of value they don't really answer his question. Let’s not fill the thread with posts telling him how "easy" it is.
    Based on the fact that he has been to CC and is now here I would assume he has had lots of people trying to pull him toward the DIY method. Not everyone is interested in going the soldering route right away.
    While I don't own either system LOR goes beyond just lighting. LOR has controllers for music and even premade sequences. However D-light is focused only on lighting with no premade sequences. I would say the best way to decide is figure out how much you want to spend and what features you are looking for. Better seems to be relative. ;)
    Default
    actually use LOR, AND DIY stuff.
    My main musical display is LOR software and controller, and a DIO card and DIO SSRs.
    I also use vixen for animated stuff with a DIO96 and some Renard16s.
    I haven't used D-Light, but i DO know that LOR is soon changing their firmware, and D-Light stuff may or may not work with their future software.
    With the low price of the LOR PC controller, I would recommend that, but again, I have no experience with D-Light.
