Results 1 to 8 of 8
Thread: colored text with contrasting colored background
    Dec 2010
    Murrieta, Ca
    554
    Default colored text with contrasting colored background
    What is the best way to accomplish this? I can't see to figure it out. I'd like colored text with a contrasting colored background.
    5 houses using:
    Renard 64, 3 Ren24's, Ren8
    4 E682 pixel controllers
    2,300 WS2801 pixel nodes
    1200 dumb RGB
    Sequenced using LSP 2.5
    Dec 2010
    Cape Coral, FL
    1,041
    Default Re: colored text with contrasting colored background
    a little more detail on your applications
    Got 100 of These connected to 10 of These controlled by one of These! Let's FLASH!
    Dec 2009
    Gresham, OR (45.483992, -122.453879)
    1,591
    If you mean that you want to be able to read the text regardless of the background color, try this:
    Code:
            public static Color getContrastingColor(Color color)
                int yiq = ((color.R * 299) + (color.G * 587) + (color.B * 114)) / 1000;
                return yiq >= 128 ? Color.Black : Color.White;
    based on YIQ
    This will always allow you to read text regardless of the background color. It is in my Utils class on just about any project dealing with color and text.
    Dec 2010
    Murrieta, Ca
    554
    I mean, using Nutcracker text class, I'd like to have a green background and have red text scroll across. I thought there was a way to do it without code or layers but I guess not.
    5 houses using:
    1200 dumb RGB
    Littleton, Colorado
    871
    Quote Originally Posted by n8huntsman View Post
    create an effect with the color_wash class. Set start and end color to green
    create a text effect with text in red, set duration the same as color_wash above
    now use the layer effect
    1) color_wash
    2) text
    and choose that effect 2 takes priority over 1.
    i created GREEN_BACKGROUND and MERRY_CHRISTMAS effects in your account.
    here is result of layer
    Effect Settings
    username n8huntsman
    user_target 5.125_32_STRINGS
    effect_class layer
    effect_name RED_TEXT_ON_GREEN
    layer_method Pri-2
    file1 5.125_32_STRINGS+GREEN_BACKGROUND.nc
    file2 5.125_32_STRINGS+MERRY_CHRISTMAS.nc
    LAYER_EFFECTS Array
    lmethod Pri-2
    frame_delay 100
    seq_duration 10
    fade_in 0
    fade_out 0
    submit Submit Form to create your effect
    OBJECT_NAME layer
    RED on GREEN is one of these contrasts that can be hard on the eyes. Maybe darken the green background more?
    Sean
    Highlands Ranch, CO
    Nutcracker RGB Sequence Builder http://nutcracker123.com/nutcracker
    Build your own 9' Nutcracker http://meighan.net/build_your_own_nutcrackers
    Littleton, Colorado
    871
    i did one more pass.
    darkened green in color_wash and added 20% sparkles (what the heck?)
    Effect Settings
    username n8huntsman
    effect_class layer
    effect_name RED_TEXT_ON_GREEN2
    layer_method Pri-2
    file1 5.125_32_STRINGS+GREEN_BACKGROUND_SPARKLE.nc
    LAYER_EFFECTS Array
    lmethod Pri-2
    frame_delay 100
    seq_duration 10
    fade_in 0
    fade_out 0
    OBJECT_NAME layer
    Sean
    Highlands Ranch, CO
    Dec 2009
    1,591
    When I am in my programming mind, I should really read what sub-forum I am in before responding. DOH!
    Dec 2010
    Murrieta, Ca
    554
    Awesome. Thanks for the help Sean.
    5 houses using:
    1200 dumb RGB
