Results 1 to 4 of 4
Thread: Hls , e681 with Firmware Version: 2.025 and lpd 6803 pixel strips .
    6,231
    Default Hls , e681 with Firmware Version: 2.025 and lpd 6803 pixel strips .
    I may have over looked something , but i have sequenced 2 strips of 32 pixels .
    If they are on seperate universes everything works fine ,
    If i try to run them in one universe hls quits working once i access the e681 config page .
    example i put 32 pixels on cluster 3-1 and 32 pixels on 3-2 , only cluster 3-1 will light light up
    if i have set up on 2 universes 32 on 3 -1 and 32 on 4 -1 all is fine .
    Any help or suggestion ?
    Richard
    e681 config included
    6,231
    Default Re: Hls , e681 with Firmware Version: 2.025 and lpd 6803 pixel strips .
    i caught my error , i have 64 pixels configured , the fix is 32 .
    Cheers
    Oakley, CA
    611
    I assume that fixed it? The E681 wasn't sending data to the second string because it thought there were another 32 pixels on the 1st string?
    Nick
    6,231
    Quote Originally Posted by n_gifford View Post
    This is correct. The # of pixels defined in the web config will apply to each socket in the cluster.
