Results 21 to 30 of 50
Thread: Android APP for testing E1.31 devices
    May 2009
    OKLAHOMA
    1,588
    Default Re: Android APP for testing sACN (E1.31) devices
    tried the app on two devices one running 2.3.5 and one running 4.04
    both failed to run
    application e131 tester (process com end.e131tester) has stopped unexpectedly. please try again
    all pix <70 univ)
    Aug 2012
    Oxnard, CA
    251
    Default
    Just wanted to say thanks for the responses. The multicast thing isn't working for me. Thanks anyways.
    Nov 2010
    Ponce, Puerto Rico
    209
    Default
    Quote Originally Posted by keebler View Post
    both failed to run
    Will try to release a version with exception/error reporting so we can see why it failed..
    RGB Mega Tree Plugin: www.varaderolights.com
    Texas
    779
    Default Re: Android APP for testing E1.31 devices
    Finally had some time to test your app and it works great! Thanx a lot for your work.
    Motorola Atrix (Gingerbread 2.6 - Stock, rooted) => works fine
    Viewsonic Gtab (Honecomb - Flashback mod) => works fine
    wanted to upgrade anyway, so I put ICS on the Gtab (Team DRH Beta 1.3) => works fine
    Toshiba Thrive (ICS 4.04 rooted Mod with Adhoc Patch) => works fine
    Tested different Universes, all and indiv. Pixels, no problems.
    Great job, this will be very helpful in a few weeks
    Mar 2011
    Orange, CA
    20
    Default
    Just tested it on my wife's kindle fire and an e681. Worked great!
    Nov 2008
    Veldhoven (Netherlands)
    368
    Tested it on 2 devices icw E681:
    - ASUS TF101 Transformer running Android 4.0 Perfect! Only 'autorotation' isn't working
    - Samsung Galaxy Y running 2.3.x.? Isn't working perfect. The last 2 sliders (green and blue) aren't functional anymore because they are outside the window...
    Nice and easy app to test your outputs.
    [URL="http://www.kerstlichtshow.nl"]KERSTSHOW / My Christmaslightshow[/URL]
    Nov 2010
    Ponce, Puerto Rico
    209
    Default
    Quote Originally Posted by henkvis View Post
    Hey,
    The autorotate is disabled on the app. I need to manually create a different layout for each orientation.
    In the same line, the missing sliders might be due to an incompatible layout for the device screen size.
    I will try to create more layouts for different screen sizes and orientations.
    Thanks for the feedback.
    Emmanuel
    Eagan, Mn.
    4,073
    At risk of sounding silly, I take it the show PC has to be connected to the internet to use this app?
    Brian
    Royersford, PA (Philly)
    1,390
    no, it shouldn't have to be, your android does need to have wifi access to the same network as the E1.31
    Nov 2008
    368
    Quote Originally Posted by nuelemma View Post
    Hey,
    Emmanuel
    Take your time.... As for my Asus-pad, it has a keyboard attached and therefore it would be nice to autorotate the screen. As for my phone, it's just the cheapest droid phone overhere Galaxy Y-xtra small orso.... Thanks for your work!
