Results 11 to 20 of 50
Thread: Android APP for testing E1.31 devices
    Royersford, PA (Philly)
    1,390
    Default Re: Android APP for testing E1.31 devices
    Crashes on Load, Droid 2 Global OS 4.5.629.A956.Verizon
    Android 2.3.4
    Nov 2010
    Ponce, Puerto Rico
    212
    I will check several things, will get back to you. Thanks for the report.
    Emmanuel
    Quote Originally Posted by pmcpa View Post
    Android 2.3.4
    RGB Mega Tree Plugin: www.varaderolights.com
    31
    hi, can't check with lights but app loads and works as it should.
    galaxy S3
    looks great, verry handy for testing! :-):-)
    greetings, robert
    Wildomar, California
    194
    Hello
    I loaded it my HP Touch w/CyanogenMod9 OS. App loads fine but can't access any E681's. Looks great for testing!
    Regards
    Jim
    Rockford, IL
    347
    Works great for me, everything from loading to controlling RPM's E1.31 to DMX board.
    Aug 2012
    Oxnard, CA
    252
    How do you change the ip address in the app?
    Nov 2010
    Ponce, Puerto Rico
    212
    Hi,
    The value showed in the App is the IP assigned to the Wifi connection. The app only reads this value.
    To change it you will need to modify your Wifi settings.
    Emmanuel
    Quote Originally Posted by vincerules View Post
    Aug 2012
    Oxnard, CA
    252
    Default
    Ok,I guess I'm not sure how to use this app. I have an ecg-p2 and the IP is 192.168.1.201.
    1,390
    That app works with multicast, you don't need to set an IP in it, it just sends the info to every ip on the network (not really, but it's the simple answer)
    Nov 2010
    Ponce, Puerto Rico
    212
    Don't worry too much about the IP displayed on the App, is there for reference only.
    Emmanuel
