Originally Posted by
BrianJ
Hi, I'm just learning HLS and sequencing so I am just figuring everything out as I go. I am sequencing mainly pixels in straight runs, eaves, windows, etc. I have a couple of questions:
Is there an easy way to run a rainbow effect across my string of pixels? Just a static rainbow for instance with red on the left side of my house and violet on the right side color morphing the full rainbow across the string of pixels.
There is several ways to do this in hls you could create a custom effefct using the effects button and add custom effect group this shown in Joes hls videos for custom effects , once you define the parameters of the custom effect and your in the sequence editor draw a selection box around the channel you would like and select the custom button to build the effect.
If I order the pixels in a group does it effect the pixel order in other groups, For instance I would like to group all the vertical runs of pixels on the windows together and reorder them for easier sequencing. Would this change the order of the pixels in the window group as well?
In short no , work groups are designed to make things easier for users to work on specific elements in the editor without having to load every channel in a users layout .
Can I save the channel layout including groups and order? The last channel save I added to the library did not include the groups and ordering.
Layout - yes
Workgroups -
Hmm , this is a good question and will need Joe's input about this being done natively in hls .
Can you select the actual effect instead of a rectangle around it? It would make moving/ lining up effects much quicker if you had a lasso type grab that only selected the active cells in an area. ( for joining chases etc. )
I dont think you will find an ez way to move things on any grid via sliding groups of effects once the grid starts gettin full of effects ..
i use the library extensively and blank areas of hls to create effects for incertion. when pasting an effect you only need to select the first time tic of where you want to place it ,anywhere on the grid .
Those are the four that I have at the top of my head. Thanks for the help.
