Results 1 to 2 of 2
Thread: Nutcracker: LOR lms file export fixed
    Littleton, Colorado
    871
    Default Nutcracker: LOR lms file export fixed
    I have fixed the regression in the LOR lms export routine.
    I have also fixed where it was only cycling the nutcracker effect once instead of cycling it to fill the sequence duration
    I have fixed it so that it only exports exactly the strings in your window_display (It was exporting strings with zeroes before for strings you might not have had)
    I fixed it so that it fills in missing strands and pixels. This should make the scrollign text clean.
    Next up, i am fixing the vixen export to have these same fixes.
    ETA, sometime this weekend.
    thanks
    Sean
    Highlands Ranch, CO
    Nutcracker RGB Sequence Builder http://nutcracker123.com/nutcracker
    Build your own 9' Nutcracker http://meighan.net/build_your_own_nutcrackers
    Jun 2007
    Amarillo, Tx
    199
    Default Re: Nutcracker: LOR lms file export fixed
    Thats one fine project, thanks for sharing, now to animate it!!
